c5 antenna
Old Apr 12, 2012 | 11:32 AM
bigcypress's Avatar
bigcypress
Default c5 antenna
looking at c5's for sale and saw a really nice 2003 a.e. convert . i was shocked to see that it had radio antenna on right rear fender . our 2000 has a radio but no antenna . why some with and some without ,the year , type of radio , or [????] ?
Old Apr 12, 2012 | 11:45 AM
raydawg357's Avatar
raydawg357
All came with antennas. Many have them in the windshield and rear glass, and some came with power antennas mounted on the rear fender. Over the years, someone probably decided to replace the power antenna with a stubby.
Old Apr 12, 2012 | 01:27 PM
DeeGee's Avatar
DeeGee
The Vert antenna is a retractable type on the rear fender. Some owners cut the wire that provideds power to extend the antenna so it doesn't extend. In a strong signal area it'll still work. You could replace it with a shorty if you wish.
The coupe has a different fit
Old Apr 16, 2012 | 10:01 PM
2525ken's Avatar
2525ken
DeDe I am attemting to put a shorty on and it has become a pain. any hints. I have a 01.thanks ken
Old Apr 16, 2012 | 10:50 PM
striper's Avatar
striper
On my Z06 I removed the antenna and filled the hole. Relocated the stock antenna inside the rear bumper.
Old Apr 16, 2012 | 11:07 PM
Marine One's Avatar
Marine One
No need to cut the wire on a vert. There is a plastic connector behind the trunk liner that can be unplugged.
Old Apr 17, 2012 | 12:33 AM
2525ken's Avatar
2525ken
need Help!!! I had a retractable and I want to put stubby. does the brass grommet that the old antenna came out of have to come out. thanks
Old Apr 17, 2012 | 12:37 AM
2525ken's Avatar
2525ken
DeeGEE I have an 01 convertiable that had the retractable antenna an I understand that some mods have to be made and just dont know what. thanks
Old Apr 17, 2012 | 03:51 PM
msgvert's Avatar
msgvert
You use he same grommet at the opening but you have to get a Z06/FRC antenna base/bracket to hold the stubby. I found a used bracket and the mounting holes did not align so great but it's in there and seems to be pretty solid.
Old Apr 17, 2012 | 06:38 PM
PhysicsDude55's Avatar
PhysicsDude55
I had the same reaction when I bought my convertible.
I changed my antenna for a hidden amplified antenna
http://forums.corvetteforum.com/c5-g...a-install.html
I would first just unplug the power connector and see if you still get good enough reception. The connector has 3 wires and you can access it from the trunk behind the antenna if you fold away the carpet pieces in the corner.
To c5 antenna
