camera setting for car shoots
Old Apr 13, 2012 | 07:56 PM
4SFED Z's Avatar
4SFED Z
Default camera setting for car shoots
I have a canon eos 500D T1i. I'm wanting to shoot some car pics...
Any tips or settings would be appreciated. Post up some pics of your work. Thanks!
Old Apr 14, 2012 | 12:44 PM
dadaroo's Avatar
dadaroo
Car shots for paint color are better done on a day that is bright but cloudy/overcast. Shooting in the bright direct sunlight is only good for getting some bright reflections. With that said, a higher number F stop will tend to put the car in focus and things in the background not in focus which is good to just direct attention to the car and not the background. A lower F stop will put everything in focus. The F stop (aperture) is setting the size opening that light will travel thorugh. Your camera may allow you to acheive this with some selections instead of full auto. Your manual should help. Otherwise you should be able to set the F stop (refer to your manual) and then the speed will be picked for proper exposure. Good luck, hope this helps some.
Old Apr 14, 2012 | 01:36 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Good info above, Make sure you have a wide lens with the car always parked close together you will need it, I shoot in raw mode so if I have a picture that I want and the color isn't correct I can edit it any way I want, You can not to that with a jpg.
I also shoot in auto mode most of the time, Todays camera's do a great job in auto mode. I am lazy..lol
Mr.Bill
Old Apr 14, 2012 | 02:15 PM
bumr's Avatar
bumr
I 'm certainly no accomplished photographer, but from my few experiences in shooting my newly acquired C5, I have agree to avoid bright sunlight. it just washes all the highlights out of the paint, except of course for the glare spots. Early morning or late afternoon are great times to shoot. Of course if you're Mr. Bill, you can produce a work of art under any conditions. Can't get enough of his pics!
Old Apr 14, 2012 | 02:21 PM
Mr.Bill's Avatar
Mr.Bill
Thank You Sir.
Old Apr 14, 2012 | 05:40 PM
Marine One's Avatar
Marine One
I always thought the opposite was the case. A higher f-stop number means a smaller aperture opening, which means greater depth of field, causing objects in front of and behind the focal point to also be in focus. Conversely a smaller f-stop number means a greater aperture opening and less depth of field, and less in focus in front or back of the focal point.
Old Apr 14, 2012 | 06:36 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Listen the Mr. Bill. He knows what he is talking about. I purchased a Nikon D5100 a few months back to get away from the point and shoot. I started in JPEG but now everything is in RAW. That I learned from Mr. Bill as well as using filters from Topaz (a totally different subject).
I will shoot in the manual mode for certain shoots where I am trying to draw your attention to a specific point in the photo.
Some random shoots
One thing I failed to mention, is you need to know is the RAW format is a large file. So if your SD card is an small one you will fill it in a hurry. I have 2 8Gig card and I was able to get over 400 shoot at Sebring. So if you do not have high capacity SD cards you may want to buy a couple. They are really inexpensive.
Old Apr 14, 2012 | 06:56 PM
ALLEGRO's Avatar
ALLEGRO
The by-product of this thread was some GREAT pics
Old Apr 14, 2012 | 07:08 PM
Flh Den's Avatar
Flh Den
Veteran: Marine Corps
St. Jude Donor '13 thru '25
You are correct my friend. Larger number = larger depth of field, smaller number = smaller depth of field.
Old Apr 14, 2012 | 07:53 PM
Marine One's Avatar
Marine One
You all had me scared for a minute. Thought my "old timers" was kicking in!
Old Apr 15, 2012 | 09:39 AM
dadaroo's Avatar
dadaroo
Sorry, I was backwards on the F stop. Was drinking beer and smoking cigars with friends at a car show by the lake. The Ferrari 458 a friend brought affected my brain.
Old Apr 15, 2012 | 11:50 AM
dadaroo's Avatar
dadaroo
Marine One-thanks for your service to our country.
Lots of people go through life wondering if they made a difference. Marines don't have to worry about that.
One of Ronald Regans greatest sayings.
Old Apr 15, 2012 | 12:42 PM
Vettedream53's Avatar
Vettedream53
Excellent job once again, Mr. Bill... Your pics are amazing!! Thanks for posting!..
Old Apr 15, 2012 | 02:52 PM
Marine One's Avatar
Marine One
Thank you.
Old Apr 15, 2012 | 02:59 PM
Marine One's Avatar
Marine One
Speakin' of things photographic, I picked this up at a yard sale yesterday for 10 bucks:
Old Apr 15, 2012 | 03:45 PM
chasboy's Avatar
chasboy
Oldtimer
Bill, I've never been able to get a good answer as to why shoot in RAW. Can you expand a little??
Old Apr 15, 2012 | 10:34 PM
Jeff in Den's Avatar
Jeff in Den
Get yourself a decent light meter..I use a Sekonic and it's dead on accurate. The camera's reflected light meter can be fooled by too many things in an image, whereas a measurement of light falling on a subject is much more accurate. An example is a black cat in the snow...your camera meter will 'see' all the white and underexpose the image, or even with spot metering on the cat you will blow the white. The solution is to measure the light falling on the scene, not reflected back. A lot of people will just chimp the histogram if they know how, but if you absolutely need to get a shot the first time, get a meter, or play with an off exposure in RAW. If you have time bracketing will ensure you get what you want and can be used in HDR if you like that stuff.
Some people like wide lenses...and for me their their place is for very crowded car shows or landscapes. Most portrait photographers will shoot their subject with a medium to long telephoto lens to compress the background and give less depth of field to the image making the subject pop.
Find what style works for you and go with it.
EF100-400 LIS lens manual exposure @ 1/500 f/5.6 ISO 100 focal length 115.0mm
EF100-400 LIS lens manual exposure @ 1/500 f/5.6 ISO 100 focal length 180.0mm
To camera setting for car shoots
Old Apr 16, 2012 | 12:11 AM
Jeff in Den
Originally Posted by Mr.Bill
Easy correction of Exposure & White Balance
are the most important reasons to shoot Raw format.
Good exposure and good white balance are the two most common problems photographers have with their pictures. If exposure & white balance are off, they can ruin otherwise good pictures, producing ...
  • pictures that are too dark or light (under or overexposure).
  • pictures with the overall color slightly off, accompanied by a yellow, green, orange, brown, magenta, or blue cast (white balance errors).
  • or pictures with a combination of exposure and white balance problems.
Good exposure & good white balance are the heart & soul of a good picture. Learn how to correct them and you'll be a lot happier with your results.
If I didn't shoot Raw, I'd often find myself struggling with a difficult, inconsistent, sometimes losing battle with exposure & white balance repairs on in-camera Jpegs or Tiffs in Photoshop. (Not fun.) On the other hand, because I do shoot Raw, I can easily correct exposure and white balance problems after the fact with some simple adjustments in my Raw processing software. Not worrying about exposure and white balance means quicker and more spontaneous shooting. (And more fun!)
That's why I let my camera automatically meter itself, leave my in-camera exposure compensation set to "0" (no compensation), and leave my camera's white balance set on automatic,concentrating my attention on composition, content, and focus point.
With Raw format, the camera captures a picture with enough surrounding data to cover two stops of over or underexposure, all possibilities of white balance, and several additional variables. Just like a regular Jpeg or Tiff, the camera sets the exposure & white balance where it (or you) think it should be according to its metering & white balance analysis ... but if they come out wrong, they can be easily reset on your computer.
Exposure Compensation and White Balance are the most important tools for Raw files, they're also the easiest to learn & use.
Raw format is a choice for virtually all modern digital SLRs and many point & shoot digitals. Nikon, Canon, Olympus, Fuji, Sigma, Pentax, Kodak Professional, and others offer Raw format shooting and have their own processing software. Besides factory branded software, independent software developers such as Bibble Labs, Capture One, QImage, Adobe (Camera Raw), and others have Raw processing software.
Bill, you should have at least gave John Cowley at Lonestar Digital credit for all of that.. http://www.lonestardigital.com/shooting_raw.htm
Old Apr 16, 2012 | 12:35 AM
atmsrus1's Avatar
atmsrus1
Man I wish I knew what all this meant...lol I have a Canon DSR and want to shoot some nice shots of anything. I bought some books to try and help me but guess I'm just an idiot cause I still can't figure it out... So I'm gonna follow this thread and see if I can learn something....Thanks
Old Apr 16, 2012 | 01:01 AM
Mecinoid's Avatar
Mecinoid
My contribution - When shooting a subject (car) and the sun is at your back watch for your shadow. Also watch for you and your camera's reflection in the cars paint. Although that can be a way to get yourself in the picture with the car.* Sometimes, you'll have to adjust the camera angle or back up and zoom in to get the shot you want.
* Don't forget about tripods and self timers they can be really helpful on a photo shoot. I should follow my own advice and get myself into some of the pictures with my cars.
Lastly, if you have a supermodel girlfriend don't forget to take some shots of her with your Vette and post them here. ;-)
