Help! DIC is reading wrong
Old Apr 17, 2012 | 12:19 PM
Rwvette2's Avatar
Rwvette2
Default Help! DIC is reading wrong
So yesterday my DIC was saying that I had a low tire(18psi) So I stopped put some air in it and then drove back to work(was at lunch) it said it only went back up to 19psi even though on my hand guide it said it was 33psi... Then last night I started my car and checked for nails or holes nothing... checked it with the hand gauge and it said it had 33psi... and the DIC is saying 14 psi... how do I fix?
Old Apr 17, 2012 | 12:24 PM
Lowcash's Avatar
Lowcash
Resync your TPMS with a speaker magnet.
Old Apr 17, 2012 | 12:25 PM
007KING's Avatar
007KING
Sounds like ur batteries in the (tps)tire pressure sensor is dying.
Old Apr 17, 2012 | 01:00 PM
Rwvette2's Avatar
Rwvette2
How do you change the batteries in the TPS? And what do they go for? Money wise?
Old Apr 17, 2012 | 01:13 PM
Rwvette2's Avatar
Rwvette2
Its an 04... So I guess I just need to replace it... And Discount can do this? They pretty expensive?
Old Apr 17, 2012 | 01:24 PM
Then newer C5 sensors ('01-04) cost about $40 each from gmpartshouse.com. A competent tire shop should be able to do the swap - they are just held in place with a nut the goes on the outside of the rim.
To Help! DIC is reading wrong
