SLP rear spoiler install
#41
I would recommend to anyone that wants a real paint match to have it painted locally by a reputable shop, I don't think it's as easy as paint it the right color, my shop told me there can be more than one tint code! They also had me bring the fuel tank cover for matching just to make sure!
I also had them put it on, a little knowledge goes a long way with something like that.
My Carravaggio fit and tint was perfect!
Just my 2 cents,
Just my 2 cents,
pdx-vette (10-11-2015)
#42
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Very easy to install just start from center pull a little backing off the tape once you get it where you want it and slowly pull the rest of the backing off and push down on the spoiler as you go. Just be sure to clean the area real good before you start. My car Is electron blue and the paint matched perfect. But some colors do fade more than others. Good luck!!
set in place, start center, and pulling the backing from beneath the SLP.
Be sure to pretreat the area where the tape is going to stick...
...then it will stay stuck!
Letting it cure overnight is a good idea too.
Good choice of a nice looking spoiler. It was my choice because it kind of lengthened the look of the rear...
That is prolly my next mod
#43
I got mine from RPI and it is Torch Red and a perfect match. You will need two people to do it right. The first thing I did was a test fit. Once I had it where it need to be I outlined it with blue painters tape. Follow the instructions on the double sided tape placement and how to remove the paper backing when installing on the car. The only area that I would redo is the one corner. We got the tape a little to close to the outer edge and it is not down flush with the body completely, but it is hard to notice.
#44
You want to take your time and install it correctly.
I suggest experimening with where you put the tape on the spoiler. I moved it inward (front and back) so that from a horizontal angle you cannot see the grey tape. It also sits much more flush to the body.
I have seen some very poorly installed, very ugly. Hope yours goes great.
#45
Just my 2 cents,
Just my 2 cents,
I am shopping for a spoiler currently for installation for the coming 2017 Mid-Western USA summer driving season.
