[Z06] Trans and differential fluid
Old Apr 17, 2012 | 06:03 PM
Bobtam's Avatar
Bobtam
Default Trans and differential fluid
Puttting a Monster stage 2 clutch in my Z and while I have everthing out I am going to change the fluid in the rear and trans. Looks like the trans holds 4 quarts but cant seem to find the capacity of the rear.
Can anyone help. Thinking of using Redline D4 for the trans and 75W-90 for the rear with additive for the limited slip. Anyone have any other suggestions?
Old Apr 17, 2012 | 06:13 PM
Paul 75 L82's Avatar
Paul 75 L82
I used Red Line first in the trans but now I've switched to Royal Purple Synchromax.
Old Apr 17, 2012 | 06:25 PM
LSOHOLIC's Avatar
LSOHOLIC
Yep.....Syncromax FTW !!
Old Apr 17, 2012 | 06:26 PM
Dennis Wilson's Avatar
Dennis Wilson
Same here. The diff will only take about 1.7 QT. DON`T over fill!! Trans will take little less than 4 QT. I have Royal Purp. in both Noticable improvement in shifting!
Old Apr 17, 2012 | 07:01 PM
Last C5's Avatar
Last C5
The rear end holds just short of 2 quarts. I've used D4 in my DD and in my track car for a long time.
The Redline 75W-90 does not need any modifier added to it, it's already in there.
The Redline 75W-90 NS does not work well in our differentials.
Old Apr 17, 2012 | 08:33 PM
Bobtam's Avatar
Bobtam
What is 75W-90 NS I looked in the Summitt catalog and saw 75W-90 recommended for limited slip dif. Are there two different 75w90?
Old Apr 18, 2012 | 01:59 AM
Last C5's Avatar
Last C5
Yes, one you want is the one it sounds like your getting ready to buy that being the 75w90 which already contains limited slip friction modifiers.
The other oil , 75w90 NS Redline, is for non-limited slip transaxles
Old Apr 18, 2012 | 09:03 AM
81c3's Avatar
81c3
Dont buy the RP. Youll be changing it in a few thousand miles.... Amsoil Torque Drive is a much better product for the transmission. Amsoil also has rear end lube for our cars. Look up Subdriver on the forum. Hes a good guy with great knowledge about fluids and lubes.
Old Apr 18, 2012 | 09:10 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Tranny... I used about 80% of the below container.
Differential ... I used 1 container, and 75% of the second one if I remember correctly. You don't need the slip lock I'm told. I just put a little in just in case. Make sure to do multiple figure 8's in a parking lot to get the fluid in the clutch packs or you risk getting gear whine.
Old Apr 18, 2012 | 03:32 PM
SuzukiDan7's Avatar
SuzukiDan7
Anyone ever try this stuff in the rear diff?
http://www.rallysportdirect.com/Motu...rce=GoogleBase
Ive had it in my WRX trans for years and its good stuff.
Old Apr 18, 2012 | 10:13 PM
MTPZ06's Avatar
MTPZ06
Ran RP in the trans and diff for about 6K miles, and it shifted well when up to operating temps, but cold shifting wasn't great. Switched to Amsoil that I got from Subdriver on here...it was noticeably better on cold shifts, and as good or better at operating temps.
Old Apr 19, 2012 | 06:40 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I use Amsoil and highly recommend it!
Old Apr 19, 2012 | 04:42 PM
Bobtam's Avatar
Bobtam
Default Amsoil
Ordered Amsoil today. Hope its as good as everone says.
Old Apr 20, 2012 | 08:23 AM
JeremyGSU's Avatar
JeremyGSU
I use the same. I did not use the Slip Lock however.
Old Apr 20, 2012 | 08:51 AM
81c3's Avatar
81c3
It is. I tried GM, then Royal Purple, now Torque Drive. The difference in shifting effort is huge.... especially when the fluid is cold. Also, I used to get a slight grind going into second gear about every 1 in a couple of hundred shifts... hasnt happened since changing to torque Drive.
BTW, I also installed the Monster Level 2 clutch. Its an excellent choice... great street manners and only a slight increase in pedal effort.
Old Apr 20, 2012 | 08:53 AM
striper's Avatar
striper
I use Royal Purple in both my trans and diff also. Many thousands of trouble free driving and absolutely no problems. So tell me, why will I be changing my oils in a few miles? RP products have worked well for me. Maybe if I could buy Amsoil locally in a store I'd try them, but when I decide its time to do a change I'd rather not have to first mail-order oil products. Convince me why I should. BTW, I tried a few different oils in my trans and RP was the smoothest, cold or warm. Also, their diff oil also does not modifier added to it, it's in it already.
Old Apr 20, 2012 | 09:01 AM
81c3's Avatar
81c3
All I can tell you is first, talk with Subdriver here on the forum. He sells the Amsoil products, but will also give you a side by side comparison of statistical information on any fluid you have an interest in. Theres many people on here who have noticed a great improvement when switching to Amsoil. I ran RP for about 10k miles and noticed an increased effort in shifting especially when cold even when the fluid was fairly new. Amsoil cured the problem for me. When warm, its as smooth as silk and I have an MGW short shifter also. Subdriver is a great guy and he had my fluid to me in 3 days. Give it a try and if you dont like it, switch back to the RP is all I can say.
To Trans and differential fluid
Old Apr 20, 2012 | 11:15 PM
MTPZ06's Avatar
MTPZ06
I used to feel the same way...but I did not like the cold shifting properties of the RP and decided I did not want to live with it any longer because I knew something must be better. Contacted Subdriver, and recived my products within a couple days of my order, and was much cheaper that what i paid for my RP off the shelf at Pep Boys. In all honesty; try or don't try it...I don't really care, its your car. But you're missing out on a superior product IMO...
100%. Same expereince with my C5Z... (minus the grind)
Old Apr 21, 2012 | 09:18 AM
LedfootLarry's Avatar
LedfootLarry
Amsoil makes some of THE best synthetics on the market. period.
Old Apr 21, 2012 | 10:38 AM
SuzukiDan7's Avatar
SuzukiDan7
Ordered the Amsoil torque-drive yesterday, hoping it helps with my cold shifting in my 02z. Ever since I switched to Mobil 1 it seems to take more effort to shift, especially when cold.
