c5 fuel filter
Old Apr 19, 2012 | 04:04 PM
showlow's Avatar
showlow
Default c5 fuel filter
i know this subject has been discussed inumeral times, however, i sure would like advice from someone who has already been there, done that.
where is it and what's the best route to go to replace it ? thanx year is 2000
Old Apr 19, 2012 | 04:58 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
It sucks. It's drivers side rear up above the exhaust pipe. Tricky to get to. You will get gas on you. The connector needs the right tool but I think I released mine by the hand. If a cat back exhaust or clutch is in your near future then is the optimal time to do it. At least it's not in the tank like some years
Old Apr 19, 2012 | 07:22 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
With a stock exhaust, its easy to access. Just above the left pipe in the rear of the car. easy to see. As already stated, you need a special tool which is just a plastic collar type thing to release the quick-disconnect. You can get them anywhere as a set of different sizes and cheap.
Old Apr 19, 2012 | 07:32 PM
sfc rick's Avatar
sfc rick
Save yourself the trouble...do like I did, Buy the gas filter and try your local shop with a lift and say....I need this filter replaced and will you do it for $20. My local muffler shop did it in 10 minutes.
Old Apr 19, 2012 | 09:50 PM
Thankfully for you it is not like mine and in the gas tank.
To c5 fuel filter
