rough rideing 99 c5
Old Apr 20, 2012 | 08:41 AM
aberson_racing3's Avatar
aberson_racing3
Cruising
Default rough rideing 99 c5
I just picked up a 99 c5 6 speed tuesday night. I am noticing it wants to wander around the road a lot and seems to ride pretty rough.. Is there any way to know if the car has been lowered and that may be whats causing is?? I dont know alot about the corvette yet. I only have about 2 hours of seat time in it... The rear tires are wore down on tread but i dont think that is the cause... Any sugestions on what to check for? thanks in advance.
Old Apr 20, 2012 | 08:42 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Shocks, alignment, tires worn out steering parts
Old Apr 20, 2012 | 08:44 AM
aberson_racing3
Cruising
It seems to be more in the rear of the car. Possibly sway bar links?
Old Apr 20, 2012 | 09:22 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
A lowered car won't cause it to wander. Sounds like your rear tires need replacing and an alignment done. Might as well replace the sway bar endlinks with aluminum ones while you're under there. Wandering (aka tramlining) can be caused by tires wider than the "ruts" in the road. Try driving on a variety of roads to see if it is consistent.
Old Apr 20, 2012 | 09:48 AM
aberson_racing3
Cruising
I am going to change the oil this afternoon and check it all out. Thanks for the help guys...
Old Apr 20, 2012 | 01:49 PM
Could be your tires need replacement as well as a check on the status of your suspension parts and alignment. For sure check the shocks to see if they are still good.
Old Apr 20, 2012 | 05:12 PM
DBLTRGR's Avatar
DBLTRGR
Originally Posted by 8VETTE7
I found the problem to be related to the very stiff sidewalls on the GY Run Craps. Problem went away when I went to non runflat tires.
Old Apr 21, 2012 | 07:26 AM
C4Boi's Avatar
C4Boi
Replace tires will make a BIG difference.
Old Apr 25, 2012 | 08:39 AM
aberson_racing3
Cruising
Put some goodyear run flats on the rear. Made it ride like a whole new car. Rides a little rough yet. Im sure thats from what you guys are saying bein runflats.. Thanks for all the help...
To rough rideing 99 c5
