C5 Radiator
Old Apr 20, 2012 | 03:05 PM
Dfactor's Avatar
Dfactor
Default C5 Radiator
I have been battling cooling issues lately. Today I noticed a rusty brown area where the top radiator hose enters the radiator. I have replaced everything but the radiator. Do you think that brown area is blow back out of the radiator meaning the radiator is bad? I can get a new one for $200 and would like to make sure that is the problem.
Old Apr 20, 2012 | 07:43 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
If you do decide to go beyond stock bet a Dewitts and the bigger fan kit...its like a freakin hurricane
Old Apr 20, 2012 | 07:55 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Clean the area off thoroughly. Start car and bring it up to temperature. Check area to determine if hose is loose or if you have a crack in the radiator, it will be apparent. What is status of coolant - if it's brown, you are way past time to change.
The biggest cause of overheating problems is clogged AC condensor and radiator fins. Vettes are bottom breathers and suck up a huge amount of junk. Make sure everything is CLEAN. There are numerous threads on cleaning - search ---
Old Apr 20, 2012 | 09:06 PM
El original's Avatar
El original
If is a brown sludge in the expansion tank..well you got big issues. It means someone mixed coolants or used tap water top up. The coolings system is corroding away! Lots more than a radiator to fix. Just pray that is not the case. Good luck, Rob
Old Apr 21, 2012 | 05:06 PM
pewter99's Avatar
pewter99
yep...that means..new radiator, water pump...t-stat and flushing the crap out
Old Apr 21, 2012 | 05:37 PM
Determine if you have a leak first, then if not, have the radiator checked for blockage.
Old Apr 21, 2012 | 07:48 PM
killain's Avatar
killain
Oldtimer
Default Bigger Fans & Dewitts
Where can I find a super upgrade set of C 5 Fans ? I'd love to step up to some super air puller fans. And does DeWitt's make a high performance C5 drop-it-in fit radiator ? :o
Old Apr 21, 2012 | 07:59 PM
pewter99's Avatar
pewter99
I bought the radiator from them about 6 years ago and I just added this fan kit which is direct plug and play....it looks awesome too
Old Apr 22, 2012 | 08:32 AM
killain's Avatar
killain
Oldtimer
Default Super fans ?
Thank you guys, this seems to be what I'm looking for ! Thank you
Old Apr 23, 2012 | 09:38 AM
Dfactor's Avatar
Dfactor
Default C5 Radiator
Thanks everyone!
To C5 Radiator
