Low Battery Level on a Key Fob
Old Apr 23, 2012 | 02:21 AM
DeeGee's Avatar
DeeGee
Default Low Battery Level on a Key Fob
I was checking out a response to another thread and just learned a new fact.
Did you know that there is a DTC that flags up a low battery level on a fob and that you can identify which fob has the problem?
I'll never stop learning things about this car.
DTC B3109
Circuit Description
The LOW battery detection is handled inside the transmitter. The transmitter sends a battery condition signal to the remote control door lock receiver (RCDLR) when the transmitter buttons are pressed.
Conditions for Setting the DTC
This code shall be set after 3 consecutive low battery signals from the same programmed transmitter.
Conditions for Clearing the DTC
This code is cleared as current when a normal transmitter voltage signal is received from any programmed transmitter.
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
This step identifies the key fob # (transmitter) with a low battery signal.
This step verifies that the battery replacement corrected the fault.
3 With the scan tool, observe the Key Fob Low Voltage parameters for each transmitter in the Key FOB Information data list to identify the programmed transmitter(s) that set the DTC.
Replace the battery(s) on the indicated transmitter(s). Refer to Transmitter Battery Replacement .
Did you complete the battery(s) replacement?
4 Use the scan tool in order to clear the DTCs.
Operate for 3 consecutive times the transmitter(s) that had the battery replaced.
Does the DTC reset?
Old Apr 23, 2012 | 06:05 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Did not know that. New lesson for the day. Thanks DeeGee.
Old Apr 23, 2012 | 07:51 AM
Thanks for the info - certainly did not know that bit of information.
Old Apr 23, 2012 | 08:20 AM
saxtech's Avatar
saxtech
From: Huntington Beach / Fountain Valley California
Old Apr 23, 2012 | 08:36 AM
roscoe118's Avatar
roscoe118
So which is it, a 1309 or 3109...
J/K
Thanks! Good info.
Old Apr 23, 2012 | 11:03 AM
DeeGee's Avatar
DeeGee
:o
J/K
Thanks! Good info.
Did you know I was doslyxic?
Edited to prevent confusion. The manual extract was correct
Old Apr 23, 2012 | 04:11 PM
Sonny71's Avatar
Sonny71
Oldtimer
Technology in these cars never ceases to amaze---thanks for the info
Old Apr 24, 2012 | 12:29 AM
Vetteriffic's Avatar
Vetteriffic
you sir are such a wealth of knowledge...even if you are dissslexxxicccc
Old Apr 24, 2012 | 12:45 AM
LS2NSUV's Avatar
LS2NSUV
I put the sexy in dyslexic.
To Low Battery Level on a Key Fob
