1999 ABS Removal
Old Apr 23, 2012 | 11:53 AM
TEXAST1's Avatar
TEXAST1
Default 1999 ABS Removal
I have a 1999 C5 that has been a track only car for a very long time. The ABS module quit working about 4 years ago. Since parts are scarce and very expensive I have not replace the module. Unfortunately, the last time I checked the 1999 cannot be repaired.
I either want to remove it and delete the ABS system entirely or possibly update to a newer system. I think I remember the 02-04' Z06 being better than my 1999.
I have not talked to anyone who can say the system can simply be removed from the car. No one seems to be sure of the results.
Can anyone help with this?
Old Apr 23, 2012 | 01:51 PM
dougbfresh's Avatar
dougbfresh
If it's just a track car, rip all the electrics out and put in one of GM's generic computers.
Old Apr 23, 2012 | 01:58 PM
TEXAST1's Avatar
TEXAST1
It has been since 1999. But I still use the dash and gauges. I think I lose those when I take out those computers.
Old Apr 23, 2012 | 02:43 PM
dougbfresh's Avatar
dougbfresh
http://www.gmperformanceparts.com/Pa...roller_Kit.jsp
Old Apr 24, 2012 | 10:13 AM
PhilsFRC's Avatar
PhilsFRC
Stand alone engine management (above) and dual (Tilton?) master cylinders (F&R) with adjustable balance bar for brake bias. Would take some fabrication, but would be a slick setup. My $.02.
Old Apr 24, 2012 | 10:35 AM
TEXAST1's Avatar
TEXAST1
I do appreciate the help with the spendy options. I have raced this car for 13 years with several sanctioning bodies and spent thousands and thousands of dollars. It is almost time to retire the car. I am really not planning on spending any real money on this option. To simply remove it would cost some time and less than $50 in parts.
I really want to make sure it can be removed and made into a non ABS car without some unforeseen consequence. It has not worked for the past 4 seasons and is now just a chunk of metal in front of the engine.
Old Apr 24, 2012 | 10:49 AM
PhilsFRC's Avatar
PhilsFRC
Disconnect it at the pump/brake control module and pull every fuse that has to do with traction control and active handling and see what happens. Without digging through the wiring diagrams, that's an educated guess. I'm not sure if that would trigger a limp home/reduced power mode and lots of codes or not. Others here are probably more knowledgeable.
Old Apr 24, 2012 | 11:00 AM
TEXAST1's Avatar
TEXAST1
It doesn't. The Traction Control and ABS are immediately disabled on my car at start up. It has been this way for years. Too much damage and degradation of components.. Now I am only looking at it from a mechanical stand point.
Old Apr 24, 2012 | 11:05 AM
dougbfresh's Avatar
dougbfresh
What's the point if you've been running around this way for years now?
Old Apr 24, 2012 | 11:10 AM
TEXAST1's Avatar
TEXAST1
That big ol' chunk of useless metal blocking the front of the engine.
I have changed the engine (rebuilt, replaced and some times rebuilt again) at least 12 times since I started racing the car in SCCA T1 back in 1999. It makes engine swaps and repair that much harder.
Secondly, it is literally dead weight. Weight is the enemy with any form of racing. If I needed ballast, hanging it out in front of the front axle on the drivers side of the car is not an ideal location.
Old Apr 24, 2012 | 11:30 AM
PhilsFRC's Avatar
PhilsFRC
Old school (pre-ABS) brakes were a (dual) master cylinder, through some sort of proprtioning valve (you may want to add an adjustable one to the rear circuit-cheap) to front and (separate) rear brake circuits. Relatively dumb hydraulic system. Some newer systems eliminate the proportioning valve by selectively engineering the master cylinder versus the caliper cylinder volumes. Take a look at the system schematics, and do a little "plumbing". That's what I'd do. If your ABS pump is now non-functional, it's merely a giant pass through hydraulic distribution block.
Old Apr 24, 2012 | 11:32 AM
dougbfresh's Avatar
dougbfresh
AGAIN, if your about to retire the car, what's the point?
Old Apr 24, 2012 | 11:56 AM
TEXAST1's Avatar
TEXAST1
Thanks. I think you are correct. My car may just be old enough to retro fit easily. There is a bronze proportioning valve sitting on the frame just below the master and I put a DRM bias spring in the master about 12 years ago.
Old Apr 24, 2012 | 12:00 PM
TEXAST1's Avatar
TEXAST1
I still have 1/2 a season to go this year and another championship to race. "About to" is not an actual concise time frame. I am thinking end of this season or 2013. Definitely not enough to justify spending any real cash on. If I had Lou's race budget I would just through the new Bosch system on and get real serious about ABS.
Old Apr 24, 2012 | 12:07 PM
PhilsFRC's Avatar
PhilsFRC
Typically the front of the master cylinder controls the front brakes and the rear the rears. What I would do (after checking the shop manual), is plumb out of the "front" side of the proportioning valve/block to both front brakes. Tie them together with a brass "T" fitting and double flare everything. Similar for the rear. You'd basically recreate a C2/C3 brake system.
To 1999 ABS Removal
