Big brake question
Old Apr 25, 2012 | 05:18 PM
Levi Walker's Avatar
Levi Walker
Default Big brake question
Is anyone using a big brake kit with a set of 18x9.5 19x11 reproduction C6 Z06 wheels?
Will C6 Z06 brakes fit?
Same wheels as this picture
*Not my car*
Old Apr 25, 2012 | 06:29 PM
Levi Walker
ttt
Old Apr 25, 2012 | 06:43 PM
SoDiezl350's Avatar
SoDiezl350
Searched and found your answer in 5min:
Originally Posted by av8rdavid
I'm in trouble....My car is also on jackstands waiting for the kit to arrive so..... I printed and tested the template to check clearence and sure enough, it doesn't clear...
I'm running reprod. C6 Z06 18 x 9.5 fronts and 19 x 10 rears..The rears look like they would clear with about a 1/4 inch hub centric spacer but the front is wayyyyyyy off needing a 1.5" bolt on spacer..
I now have to figure out what this is going to look like...If the front sticks out beyond the fenders, i'm out...
http://forums.corvetteforum.com/1577295589-post10.html
Old Apr 26, 2012 | 12:42 AM
yaknow's Avatar
yaknow
I running C6 Z51 brakes with the same size tires and wheels with no issues
Old Apr 26, 2012 | 02:50 PM
tiojames's Avatar
tiojames
The C6 Z06 front calipers need 5/8" more offset than the stock C5 calipers. Take a tape measure and measure the distance from the inside of your present wheel's spokes to the outside of your present calipers. If you have 3/4" you are good to go. If not you will have to add a spacer to make up the difference. I got my spacers from DRM (a forum sponsor). C6 Z51 calipers are no the same as the Z06.
To Big brake question
