If your now going FI, Get as much air into the engine bay as possible as you are adding a trans cooler and intercooler, Do the plate mod, I've done several for members, let me know if you need any help! I run twin B&Ms with no fan, about $60 from Summit or Jegs!
QUOTE=robert miller;1580670921]I have a great set up will sale you was only on the car less than 2,k -10 A/N fitting on input and out..... Robert[/QUOTE]
That looks great! I have the T/S so there is no plate. But I bet i could do something with the grill in the front for more air. Thanks for the idea. I was concerned about the rubber hoses on the coolers.
Bypass the radiator - it is not needed. You do not need to share heat from the motor too the tranny - just pull it out of the radiator and hook the lines into the cooler - one in and one out - it can go either way!
Let me know if you need some pics of how I mounted mine - this cooler is way better than the B&M, there is way more surface and it keeps the temps way down - especially since I run a 3200 stall and a Supercharger!
