cruise control
Old May 6, 2012 | 01:16 PM
rayz1951's Avatar
rayz1951
Default cruise control
I couldn't get the cruise to work today. I checked the fuse and its good. Does the traction control have to be off for cruise to work?
Not that I use it that much but I like everything to work properly.
Ray Z
Old May 6, 2012 | 01:19 PM
Jistari's Avatar
Jistari
Nope.
E Brake pulled up a few clicks? Could happen while you're cleaning by accident.
Old May 6, 2012 | 08:44 PM
sunchaser73's Avatar
sunchaser73
Check the setting of the cruise control release switch on the clutch pedal. Mine was way out of adjustment...easy fix.
Old May 6, 2012 | 09:02 PM
The cruise control will work with traction control on. Could you perhaps have a brake switch that is stuck or a stop lamp switch that is stuck? Just throwing out some guesses.
Old May 6, 2012 | 10:25 PM
o2bnkc's Avatar
o2bnkc
My guess, is that the switch by your pedal is bad.
Old May 7, 2012 | 02:51 AM
DeeGee's Avatar
DeeGee
It could be one of a few switches
Check the codes and post up. It should show which one has failed.
Old May 7, 2012 | 07:31 AM
matthewlfd's Avatar
matthewlfd
As posted earlier, the most likely cause is either one of the switches on the brake or clutch pedal. They just have plastic retainers that snap in and can back out pretty easily. Try lifting up on either pedal with the top of your foot and see if that lets you engage cruise.
Sounds like you need to pull off the plastic cover and check them out.
Old May 7, 2012 | 04:02 PM
rayz1951's Avatar
rayz1951
I changed the switch on the clutch pedal, problem fixed! Thank you for the info.
To cruise control
