Is it possible to pull a C5 engine from top??
Old May 8, 2012 | 12:19 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Default Is it possible to pull a C5 engine from top??
Ive heard they must come out thru the bottom...I need to pull one with a rod knock....Dont have a lift
Old May 8, 2012 | 07:31 AM
sfc rick's Avatar
sfc rick
You can pull from the top, but you still have to jack the front end up enough to drop the front cradle down an inch or two.
Old May 8, 2012 | 09:32 AM
Pete W's Avatar
Pete W
There is a write up on here about a guy doing a motor swap and build up, that pulled the motor from the top. Let me see if I can find a link.
Here it is:
http://forums.corvetteforum.com/c5-t...-up-kinda.html
Old May 8, 2012 | 10:08 AM
The NNIAL8R
Here it is:
So it can be done....THANKS!!!
Old May 16, 2012 | 01:10 AM
BLWN1's Avatar
BLWN1
Im about to install one from the top, Ill read the thread later... thanks for the heads up on it.
To Is it possible to pull a C5 engine from top??
