Taylor Plug Wire
Old May 10, 2012 | 09:34 AM
Dale002's Avatar
Dale002
Default Taylor Plug Wire
Any one using these wires and if so would you recomend them?
Old May 10, 2012 | 01:26 PM
Qwik01's Avatar
Qwik01
I was running MSD wires for a while and switched to these. Love them so far. They lock into position much easier than the MSD's did.
Old May 10, 2012 | 01:52 PM
baxsom's Avatar
baxsom
dont say anything about how bad the MSD locks on. I got yelled at for it by a vendor.
Old May 10, 2012 | 02:02 PM
theheartbeat's Avatar
theheartbeat
had them on my other car biggest Pices of S*** ive ever had
Old May 10, 2012 | 02:04 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
When I changed my plugs, I broke 2 of the wires, pulled them right out of the snap clip that goes on the plug. I called MSD and they said I pulled them off wrong. MSD coils and plug wires for C5s suck!
I have a few buddies with Taylor wires and seem to be happy with them!
Old May 10, 2012 | 02:07 PM
JeffT1's Avatar
JeffT1
I've had the metal clip on the spark plug end pull through the boot on more than a couple of sets of Taylor's. The MSD's are a little more vague on the spark plug end when making that connection but I've never had one pull through when changing plugs.
Old May 10, 2012 | 02:42 PM
dankhts's Avatar
dankhts
never used them on my C5, but had them on the Camaro, hate them, P.O.S..... never will use them again.... they don't last long, and seem to fall apart when you change plugs.... on the C5, I've been using GMPP wires...
Old May 10, 2012 | 04:37 PM
baddboyz03's Avatar
baddboyz03
I use them with the heat socks. work very well!
Old May 10, 2012 | 05:21 PM
jornahow's Avatar
jornahow
I used Taylors on my C4; they were Ok, at least as good as MSD. On The C5 I use Magnecor; I consider them the best, but they are more expensive.
Old May 10, 2012 | 07:05 PM
C5Wolfe's Avatar
C5Wolfe
I run MSD 8.5s and I like them fine! I do use the heat socks on a couple of the plugwires because of my headers though!
Old May 10, 2012 | 10:37 PM
Qwik01's Avatar
Qwik01
If they're bad then they are bad. I didn't buy from any vendor on here anyways. Not a bad plug. Its just they don't seem to lock it good at all if you ever remove them and put them back on. I kept getting miss fires and had to switch to the Taylor's. Taken them off a couple times and they snap right back into place.
Old May 11, 2012 | 09:53 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Got GMPP Red Wires on my 99. Love them and they were only $60.
Old May 11, 2012 | 10:03 AM
Dale002's Avatar
Dale002
I'm looking at taylor and now Moroso because of the blue color. It will match some other trim pieces in my engine compartment. I have a set of old gm red wires. I took one to the parts store and compare to the taylors, didn't see much different on the visual parst of them. The inner core and the way it connects to the boot at the plugs seems the same. I starting to think that all the wires in the price range of $50 to $100 are pretty much the same quality.
To Taylor Plug Wire
