Rear Quarter Panels..
Each of these flares will most likely require some prep work, and if your going to do most of the work yourself you will save a lot. I'll give a simple break down in price that will vary:
L5 flares $899 - $999
TEP $899 - $999
Qwik z06 $450 - $550 (Sorry Pete can't remember exactly, lol)
Qwik z06 $600 - $750 (Carbon Fiber)
Splash guards will vary. You can pay from $120 a set to $300. I went with c6 z06 OEM. Keep in mind to fit the OEM will need to be modified but fairly simple to do.
Paint will also vary. I paid $410 for prep and paint only (color: torch red) I did the install. Depending on your color, and who does the paint the price will vary. $400 - $800 depending on prep work and paint.
I can give you a sample of my total cost, but keep in mind I did all the test fitting, and my body shop did the prep work.
Flares
$300 (it was this price since they were the prototypes, and extra prep work was anticipated)
$410 Prep and paint (installation and test fitting not included as I did my own)
$90 OEM c6 z06 splash guards new from a forum member (tasteetwirl) thanks
Total = $800
I did not include shipping as it will also vary. Realistically, most will pay anywhere from $1500 to $2000 when all said and done.
See links below for additional info:
http://forums.corvetteforum.com/c5-g...er-flares.html
http://forums.corvetteforum.com/c5-g...06-teaser.html
TEP $899 - $999
Great Reply!!! Thank you!
TEP $899 - $999
If you're buying fenders, you're probably going to want new wheels that are about 12" wide. If you do that, the safe money is to set aside about $5,000. That will cover paint, fitting (if the fenders have any fitment issues), splash guards, a set of $1,600ish wheels and $2,000 tires.
the costs are quite a bit more then just the parts and paint.
i did it or had it done but would not do it again on a C5. A C6 yes as you can get pre painted Wide GS or Z06 body parts very easily
Here is my list of mods and as you can see some money has been dropped into the car. The car is paid off pretty much but I don't want a car note and a c6z is still pretty high in price.
But still just doing fender flairs is not always the best way
Good custom wheels with 315 rear tires is quite a bit of traction.
They do look cool
