Strange Start Issue??
Old May 18, 2012 | 03:01 PM
WildTurkey's Avatar
WildTurkey
Default Strange Start Issue??
I encountered a strange problem today with my vette. When I tried to start the car - nothing. I knew my battery was fully charged. I tried several times and nothing. I got out of the car, waited a few minutes, then tried again and it started. When I got home, I turned it off and tried to start it again, and no problem, started right up. Weird. Has anyone else encountered something like this?
Old May 18, 2012 | 03:24 PM
2004c5blackcoupe's Avatar
2004c5blackcoupe
Try cleaning the chip on the key or use a different key.
Old May 18, 2012 | 03:27 PM
Could be a problem with the VATS system.
Old May 18, 2012 | 03:35 PM
2004c5blackcoupe
Check this link out...
C5 ignition switch repair by Bill Curllee
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old May 18, 2012 | 03:58 PM
WildTurkey's Avatar
WildTurkey
Great information - Thank You!
Old May 18, 2012 | 06:01 PM
Kevin Kuse's Avatar
Kevin Kuse
Clean your battery terminals and check & clean your grounds at.
G104 Instrument panel harness, Rear of RH wheelhouse, between battery and U/H electrical center.
G106 Engine harness, RH side of the engine above the starter.
Old May 19, 2012 | 10:14 AM
BeanCntr's Avatar
BeanCntr
Default Weird starting
How old is your battery, sometimes the battery will be fully charged and everything but starting seems to work...what happens is that after time some debris inside the battery shorts out a cell and causes it to not have the required amps to start it..can be intermittent until the debris has built up enough that the cell is totally shorted out. Just a thought.
Old May 19, 2012 | 10:40 AM
TC_1961's Avatar
TC_1961
Happened to me last night!!!!!!!
To Strange Start Issue??
