C5 Car Care Help
Old May 28, 2012 | 11:06 AM
TFJM's Avatar
TFJM
Default C5 Car Care Help
New '02 C5 owner here. Is it wise to run C5 thru automated brushless car wash? Some car washers have an under carriage rinse. It is smart to do that?
Also, is the Absorber the best to use to wipe car down after wash? Is there something better?
And any particular car washes, wheel & tire cleaning products that are better than others? There's just so many to choose from.
Any feedback would be appreciated.
Old May 28, 2012 | 11:08 AM
Corvette_Ed's Avatar
Corvette_Ed
Running your Vette through a carwash would not be smart. ALWAYS wash your Vette by hand, or have someone else wash it by hand if you can't.
Many use a leaf blower to blow off water after a wash and a shammy or microfiber towel to finish the drying.
Meguiar's and Adams seem to be two of the top brands, as are Zaino and Invisible Glass.
Go to Autogeek.com, Meguiars.com, and/or Adams.com to watch their tutorial videos.
I would suggest you strip your wax using Dawn, do a clay bar detail cleaning, and follow this with a good polish & wax.
Kale's Avatar
Kale
No. Many car washes can damage the bits and pieces on the bottom of the Corvette.
There is a car care section. Be warned though: It's 95% advertisement and 5% actual member posts.
Old May 28, 2012 | 11:19 AM
Oldvetter's Avatar
Oldvetter
I agree, never use a brush car wash, it's tracks can cause problems too.
There are brushless car washers that have an under carriage washer, you can use those.
I use microfiber cloths to dry after using a water blade.
I find Meguiers "All Wheels" wheel cleaner works well and their "Endurance" tire dressing lasts a long time and is easy to apply.
Oh, and California type (wax coated) dusters are great to use between washes to keep the car looking good. I use 3 of them: one for body, a "Dash One" for interior, and another "Dash One" for the wheels.
Old May 28, 2012 | 12:07 PM
chasboy's Avatar
chasboy
Oldtimer
I have OLD horsehair brushes that were used by Hertz. No scratch and they work great.
However, I've heard the tracks in the car wash can raise havoc with our wheels.
Old May 28, 2012 | 12:44 PM
I have never run my car through an automatic car wash - I either wash it by hand or use a self serve car wash that has a wand type sprayer - it's good for cleaning wheel wells and the undercarriage.
I use an Absorber to wipe my car down - does a good job and has not had any ill effects on the paint. Just keep it clean is all.
I do use a California Duster on mine in between washes to keep the dust off the finish.
Old May 28, 2012 | 12:48 PM
PryOpenUr3rdEye's Avatar
PryOpenUr3rdEye
Run it through an automatic and the flood will begin!
If your rubber is bad enough you'll feel like you are recreating the water-coffin escape trick!
Old May 28, 2012 | 05:45 PM
04blackice's Avatar
04blackice
Those touchless are useless.but if they salt roads where u live.then i would run it through just to get salt from under car.otherwise use microfiber mit and do it yourself.good luck
Old May 28, 2012 | 06:23 PM
Mastertvtech's Avatar
Mastertvtech
I almost always hand wash my vehicles...When the weather doesn't permit, I use the touchless high pressure wash. I always wipe it down with the absorber and have never had any issues.....I would never go through any other type of automatic wash though.
Old May 28, 2012 | 06:48 PM
04blackice's Avatar
04blackice
Even betr. I use self car wash.take my own soap and mit.do it at night when its cool.use spot free rince.drive home park it.wake up and ita dry no spots.love it.only spend 5 or 6 bucks
Old May 28, 2012 | 07:31 PM
jrprich's Avatar
jrprich
I have used a touch less many times with no damage and good results. The rails have never been an issue for my wheels/tires
Old May 28, 2012 | 08:59 PM
04blackice's Avatar
04blackice
The touchless is ok to rinse it off but just spraying soap dosent clean it.it still leaves film of dirt on car.if were talking same thing
Old May 28, 2012 | 09:21 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
For me I do the washing myself to know everything that is going on on the Vette -
I really do not trust a machine and the lowness of the Vette, damage could happen and I would rather not take that chance - especially since they will not stand behind any damage done to your Vette - you will do it at your own risk and damage!
Better to get it Hand Washed by a professional who will come to your home or work to get it done right or a true hand car wash to get it cleaned - or do it yourself!
Thanks,Matt
Old May 28, 2012 | 09:57 PM
jrprich's Avatar
jrprich
Depends on the system. The one I use does not leave a film at all.
I also hand wash my cars when the weather permits, but in the PNW hand washing is not always possible.
Old May 28, 2012 | 10:04 PM
killain's Avatar
killain
Oldtimer
Default Car washing. . .
Thanks,Matt
There is a lot of a machine in a automated car wash, the vette gets wipe-down with harsh brushes of and the car isn't even with yet other than the water in the brushes, then the car goes through all sorts of water and a soap cycle and at the end is high pressure air to push the water off then some guys wipe your car down with towels, at any rate, I personally never that my corvette through a car wash. I don't give a damn if it's dirty, I'll wash it when I get time.
Old May 29, 2012 | 10:15 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I only hand wash mine. I use a Calif Water Blade then chamois. I like P21-S wheel cleaner for the wheels. I delute a little Simple Green in water for under hood clean-up. Enjoy the hands on cleaning!
Old May 29, 2012 | 10:59 AM
OkieBikerDude's Avatar
OkieBikerDude
I do not use an automated car wash of any kind for fear of possible undercarriage damage. I go to a self wash and use the wand for cleaning wheel wells and under the car if necessary.
Dawn for a serious wash (removes wax) after a road trip and Turtle Wax car wash for routine cleaning. I dry the car with a Sham Wow or chamois if at home. I use a California Car duster most often as my car is not a daily driver.
Mother's or Meguire's for polish with an orbital buffer (slow speed) followed by a coat of Collinite 476S paste.
If you buy a name brand product and follow the directions you should be in good shape.
Good luck and welcome to the Forum.
OBD
Goo
Old May 29, 2012 | 11:30 AM
Sonny71's Avatar
Sonny71
Oldtimer
Hand wash is best, I've had no problem with the Absorber, others may disagree.
I use Meguiers Classic Gold Wax, Detailer and Quik Wax and the California Duster.
Good Luck and welcome to the Forum, I'm sure you'll get plenty of feedback.
Remember to WAVE
Old May 29, 2012 | 01:28 PM
Aerovette's Avatar
Aerovette
I would NEVER EVER wipe my car down with ANYTHING, if it was not washed by hand. You are taking the film of dirt left behind (yes, it's there) and rubbing it into the finish.
To C5 Car Care Help
