I've tried it both ways and I perfer a piece that runs the length of the crossmember. When I tried it with blocks on each end and a long board under that, the longer board started to flex in the middle where there was no support so I let it back down and switch it. Better safe than sorry. I like that Summit one, looks like what I was talking about but the one I saw was homemade and not adjustable.
..... It flexed some but it didn't crack or even act like it was going to. Treated boards offer added strength as well....
Just the opposite is true.
The treating process doesn't add strength to a piece of wood. It just makes the wood less tasty to insects and more resistant to rot.
Of a greater concern is the fact that treated wood is usually made from Southern Yellow Pine, one of the cruddiest woods around. It's prone to checking and cracking unlike the woods used for framing lumber such as hemlock and fir.
If you want a strong wood, look for a hard wood like oak, maple, cherry, etc.
If you want to use a 'soft' wood like fir, hemlock, etc., then look for something without knots, straight-grained, or quartersawn (if you can find it).
I use a 2"X6"X25" on the front and a 26" piece on the rear. I've glued and screwed a 6"X6" piece of 3/4" plywood on each end to put the load on the ends of the 2"X6" and to prevent possible splitting.
I like the look of the metal pieces; However it looks like it would necessary to get each end of the car about 6" off of the ground to get the jack in place. My wooden pieces work with 3" ramps under each wheel.
...I like the look of the metal pieces; However it looks like it would necessary to get each end of the car about 6" off of the ground to get the jack in place. My wooden pieces work with 3" ramps under each wheel...
Using this combination, it is just plug and play. The jack is the ATD-7325 (same one as the Omega 29023, just under a different badge)
Do you honestly think the cross member is going to bend due to jacking it up in the middle?
I've worked on 10+ C5s and never bent a cross member yet. But by all means, go to what ever level you want in order to feel comfortable working on your cars.
This was how my car spent 6 weeks this spring while rebuilding the engine. Not a lot of wood used in that little effort.
I've jacked my car dozens of times in the center of the crossmember no with no issues. I wonder what some people would think when they see the entire side of the car off the ground when I jack it on the frame rail to do a rotor change at the track. Never had an issue and never will.
