Jack Stands Question
Old May 28, 2012 | 12:36 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Jack Stands Question
I've read the threads on proper jacking, etc. and how to position the jack stands under the front and rear cross members.
Can anyone recommend the correct length/width of wood pieces required? I understand the goal is to position 2 blocks on top of the 1 longer block that runs the length of the cross members.
I have a project that will require me to remove all four wheels at one time and need to do this the right way.
Thanks!
Old May 28, 2012 | 12:43 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I will use a piece of 2x4 that is just a little shorter then the cross members.
Old May 28, 2012 | 12:52 PM
MSG C5's Avatar
MSG C5
Thanks. Can I get by with one 2X4 section or three per the pictures below?
Any reason why there are two shorter blocks above the cross member section?
Old May 28, 2012 | 01:10 PM
GCG's Avatar
GCG
I'm my opinion the first one is fine if you use it only as pictured: to support the car with jack stands, but not for jacking. If you use it for jacking all the force will be applied at the center point of the cross member!
The second one uses two shorter blocks so you can jack from its center, while appliying the force at both ends of the cross member, avoiding a potential problem.
Old May 28, 2012 | 01:27 PM
IRON MAIDEN's Avatar
IRON MAIDEN
I use 2x6 as it positions over the entire flat portion of the crossmember. I'm actually using the composite deck boards for it and they are 1x6. I have two different pieces for the front and rear. For the front, I have two pieces glued and screwed together to make it 2x6 and the length is just shy of the lower control arms. For the rear, I use a single piece of the 1x6 that is just longer than the crossmember. I don't double up on the rear as when I lift the front up, I can't get the jack under the rear with a 2x6. Once I get the rear up with the jack, I use a couple extra 1x6 blocks to double up the ends where the stands are placed.
All this is achieved after I have driven the car up on ramps (front ramps are about 4" high, rear 2") so that I have a little room to work with the jack. And yes, it's a low profile jack but these cars are so low that I can't even get the jack and the 2x6 block under the crossmember at ride height. A 2 post lift would sure be nice!!!
For safety, I also position 4 jack stands at the rocker(puck) locations. They do not carry the weight of the car but are there just in case. I also have a huge block of wood that is about 12x16 that I place between the jack stands in the front or rear depending upon what side I'm working, again....to catch the car just in case.
Old May 28, 2012 | 01:37 PM
IRON MAIDEN
No way. If you jack from the center, that 2x4 is gonna flex and then crack. Now if the two upper blocks touching the crossmember were longer and only allowed a few inches of gap to at least support the jacking area, then I don't see a problem.
The best design I've seen, and I plan on making one, was made of 1x6 box tubing(steel). Just like above but welded up steel. The area that touched the crossmember has rubber pads on it and wings that would cup the crossmember so it was locked in position. I saw it somewhere on this site.
Old May 28, 2012 | 03:37 PM
Must_Have_Z's Avatar
Must_Have_Z
I think you're overcomplicating this. Just get something solid like a 1 x 6 piece of pine that runs the length of the cross member, jack it in the middle, and you'll be just fine. The board won't crack, you're spreading a lot of the lifting force across the cross member (not just in the middle), and it will only take you a few bucks and a few minutes to get the board, cut it, and lift the car. This is the setup I use and it's been perfectly rock solid. People put way too much thought into things like this (IMHO).
Old May 28, 2012 | 04:24 PM
2004c5blackcoupe's Avatar
2004c5blackcoupe
Here you go:
http://forums.corvetteforum.com/c6-c...g-c6-pics.html
Old May 28, 2012 | 04:39 PM
GCG's Avatar
GCG
Originally Posted by IRON MAIDEN
No way. If you jack from the center, that 2x4 is gonna flex and then crack...
Have you tried? That argument has been put on the table several times. People who use this setup swear by it and say it's safe, others don't agree... Me, personally, this is what I use:
Old May 28, 2012 | 05:38 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Actually no it won't. I used 2x6's instead of 2x4 and I first thought the same thing. But it lifted right up. It flexed some but it didn't crack or even act like it was going to. Treated boards offer added strength as well.
I am going to get some of the cross members pictured above at some point though. They aren't very expensive at all.
Omaha02Z06's Avatar
Omaha02Z06
I just went and measured the peices of 2x6 that I've been using and they are 25'' long.
Oh and this is the link I found shortly after getting my car and it has worked for me. http://www.z06vette.com/diy_lift.php The longest the car has been in the air using this method was a little more than a week.
Old May 28, 2012 | 05:45 PM
RetiredSFC 97
Here's the write up on how to build the wood ones.
http://forums.corvetteforum.com/c5-g...ting-pads.html
Old May 28, 2012 | 06:05 PM
MSG C5's Avatar
MSG C5
Nice. What is this and who makes it?
Old May 28, 2012 | 06:34 PM
2004c5blackcoupe
available at summit racing
http://www.summitracing.com/search/B.../?autoview=SKU
Has anyone made one of these?
Old May 28, 2012 | 06:52 PM
RetiredSFC 97
By the time you bought the parts it would most likely end up costing more.
Old May 28, 2012 | 08:01 PM
SeattleVette's Avatar
SeattleVette
This looks like the hot ticket and I don't have to saw, glue or nail anything. How does this adapt to the jack? I'm assuming just a 1/2" or so long round stub that goes into where the jack lifts in place of the saddle... Correct?
Old May 28, 2012 | 09:00 PM
TorchRedRocket's Avatar
TorchRedRocket
Couldn't agree more.
To Jack Stands Question
Old May 28, 2012 | 09:15 PM
CactusCat's Avatar
CactusCat
Or.......... you could make one of these instead ! http://corvettec3.ca/ramps.htm
Now that is what you really call overcomplicating it . . . .
I know, I know... my mind tends to wander.
Old May 28, 2012 | 09:36 PM
MSG C5's Avatar
MSG C5
Thanks!
Old May 28, 2012 | 10:50 PM
2004c5blackcoupe
Looks like it bolts onto the jack:
http://static.summitracing.com/globa...sum-918008.pdf
