Gas Cap Probs.
Old May 29, 2012 | 01:43 PM
KUKUSE2000's Avatar
KUKUSE2000
Default Gas Cap Probs.
I have bought 3 gas caps in the past 2 years for my 2000 vette they seem not to want to tighten after a period of time the lastest was bought today at Chevy for 25 bucks, is this something that is common? I also hear air escaping from the filler pipe sometimes when I remove the cap to refuel, where would that be coming from and is that normal????
Thanks all,
Kukuse2000
Old May 29, 2012 | 03:40 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Do you mean that when you put it back on and turn it to tighten, it does not get to the point where you hear that ratchet like sound?
Old May 29, 2012 | 03:45 PM
KUKUSE2000's Avatar
KUKUSE2000
No when I go to tighten it up it just clicks as if it is tight but it's not the cap can be taken right off without turning the cap
Old May 29, 2012 | 03:46 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I think you may want to have the filler neck checked.
Old May 29, 2012 | 03:48 PM
KUKUSE2000's Avatar
KUKUSE2000
What about the sound of escaping air when it is tight and I remove the gas cap?
Old May 29, 2012 | 03:52 PM
Mine will do that, especially on a warm day. Pressure does build up and that is what I think you are hearing.
Old May 29, 2012 | 03:55 PM
KUKUSE2000's Avatar
KUKUSE2000
ok that could be just that I thought that someting wasn't venting correctly on the engine and that was causing my gas caps to go bad. thanks Vetteman Jack and also TR6speed If anyone else has thoughts please share I'm at wits end on this Gas cap thing
Old May 29, 2012 | 04:39 PM
jrose7004's Avatar
jrose7004
I have had two C5's and definately haven't had any trouble getting the gas cap to tighten. Like someone stated, I would be looking for problems with the filler neck.
Old May 29, 2012 | 05:40 PM
KUKUSE2000's Avatar
KUKUSE2000
Thanks JROSE7004 I had seen a deal on the C-6s about fuel cap prob. and thought maybe we had some of the same issuses here with ours??????
Old May 29, 2012 | 06:08 PM
mcgilles's Avatar
mcgilles
That one is normal. Heat can cause it.on a hot summers day when you pull into the station the tank has mostly air in it which pressurized with heat.
Also the evaporative emissions system intentionally pressurizes the tank to prevent fuel from evaporating. If it's still got pressure when you open it that's a good thing. I think 99% of the time its just not enough to notice. I think the manual actually says to open the cap slowly due to pressure.
As for the cap not sealing...have the filler. Checked. And make sure you are getting it on there straight.
Old May 29, 2012 | 06:18 PM
Corvette_Ed's Avatar
Corvette_Ed
If the cap isn't tightening, and the OP has already changed it three times, it's time to look for something else being the root of the problem. There are only two parts that could possibly cause the problem, so if it isn't the gas cap, it's got to be the filler neck. Occam's razor.
Old May 29, 2012 | 08:58 PM
KUKUSE2000's Avatar
KUKUSE2000
I got the new cap and tried it useing my hand and the new one turned to the right with a lot of resistance before it started to click. the old one turned and clicked real easy without any resistance. So I feel like it was just a weak drag on the turning part or maybe I had always turned it to much , I don't know but it's sealing great now if this reoccurs then the Chevy dealer will have to explain. But going forward I want to thank all who have tried to point me in the right direction.
To Gas Cap Probs.
