Window Regulator P/N
Old Jun 1, 2012 | 10:34 AM
FYNL4's Avatar
FYNL4
Default Window Regulator P/N
2002 Vert.
Does anyone know the ACDelco P/N for the passenger side window regulator? Amazon lists ACDelco 15781690 Front Side Window Regulator Assembly but the lone customer review says this P/N did not fit.
Old Jun 1, 2012 | 01:59 PM
c3andc5's Avatar
c3andc5
You will find it on www.acdelco.com
or
www.gmpartsdepartment.com
Old Jun 1, 2012 | 02:14 PM
feeder82's Avatar
feeder82
gm part # RH reg with motor 98-02
sorry checked # it was bad
Old Jun 1, 2012 | 03:58 PM
FYNL4's Avatar
FYNL4
[QUOTE=c3andc5;1580962924]You will find it on www.acdelco.com
The above link to ACDelco supplied by c3andc5 confirms the P/N listed as correct. Thanks for the reply.
Old Jun 3, 2012 | 02:47 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
You will also need a connector or it won't work. I would be happy to help you out with the connector and regulator!
To Window Regulator P/N
