Which Mobil1?
Now Mobil1 comes in 4 different flavors. This is a summary of their specifications for 5w30 viscosity:
- Mobil1 Extended Performance5W30 (GMdexos1, GM4718M)
- Mobil15W30 (GMdexos1, GM4718M)
- Mobil1 Advanced Fuel Economy0W30 (GM4718M)
- Mobil1 High Mileage5W30 (No GM recommendations)
Any one of the other 3 should be fine, according to their specifications. In Walmart the Extended Performance is more expensive than the other 2 and these, in turn, cost the same.
The Extended Performance is said to last for 15k or 1 year. If we go by price, and you don't drive more than 15k in a year, it makes no sense to buy it.
So my question is, in your opinion, having both "Mobil1 5W30" and "Mobil1 Advanced Fuel Economy 0W30" in front of you, side by side, in the store shelves and at the same price, which one would you buy?
I'm copying here Post #21, which is a direct result of this exchange of information, to facilitate the process of getting up to speed with this thread.
Post #21:
The best of all the above is the high milleage one.This is the exact same oil like the dexos 5w30 but with a way better additive package(zinc 1100 ppm, phorphorus 1000 ppm ).Zinc.phosphorus and zddp protect the cam,rocker etc.
http://69.89.75.22/product.aspx?pid=121&pcid=1
Wanting to find more info on this subject, I went to "Bob Is The Oil Guy" website and found an interesting paper by Dr. Ali E. Haas (AE Haas): Motor Oil University. It is divided in chapters, each touching a different aspect, to facilitate reading.
To my surprise, Chapter #7: Motor Oil 107 (bottom of the page) doesn't agree with the ZDDP concerns expressed above:
There are other additives. Some newer oils do not have any ZDDP, and they are excellent products. Just the same, I prefer oils with ZDP for now. The research shows that 0.03 is all that is needed and has the same function as higher levels. The only reason to have more is because your engine is consuming the ZDDP secondary to borderline lubrication from oil alone.
And lastly, too much can be corrosive itself and has shown in some tests to actually increase wear.
the 0-30 is thin which is where the fuel mileage comes from. really thin oils scare me in performance applications. yes they are worth a couple hp but cam scaring and piston ring wear also are more likely with thinner oils
so, i guess that puts me with option #2 as well
unless you spend 2x as much on amsoil, royal purple or redline i haven't seen anything in wear tests over at bob is the oil guy concerning valvoline syn, castrol syn, penzoil platinum or mobil1 to make me favor one more than the other. personally i buy the cheapest of those 4 whenever i walk into walmart. prices, at least here tend to change weekly. i will admit that castrol is my least favorite of the 4 and i have no real idea why
a diesel or highway geared v8 gas engine cruises about 1500rpm
a high winding performance 4 cylinder like the honda type r cruises 3500-4000rpm
the honda has between 2 and 3 times the amount of piston travel in a typical 3000 mile drive. high rpms also tend to allow more blow by of combustion gases into the crankcase.
so, how can an oil that goes say 5000 miles even in example number 1 claim to do the same in example number 2
Then i ll switch to some full synthec RL 0w30 wich is ester based oils.I choose the 0w30 because there 5w30 is thicker than a normal 5w30 grade and thicker is not always better.Are engine require good oil flow and less restriction.
M1 5W-30 has nominally 800 ppm of phosphorus.
To increase 7 litres to 1,000 ppm will take 2.5 oz of RL Break-In Additive.
1,100 ppm will take 4 oz.
1,200 ppm will take 5.25 oz.
1,300 ppm will take 6.5 oz.
How high a P level you want is up to you but I wouldn't go higher than 1,300 ppm. Personally I think 1,000 ppm is fine.
I'm with the #2 crowd.
