BSMs Removed
Old Jun 2, 2012 | 08:45 PM
633K's Avatar
633K
Cruising
Default BSMs Removed
Great day today. I removed the BSMs from my C5. It went quite well with the help I had from a friend (another forum member). I've got some pretty nasty blisters on my thumbs and one of my fingers, but all in all it was definitely worth it. The car looks so very much better without them.
Before:
Work in progress:
Even more beautiful than before:
And the crispy critter I found, cooked on the radiator.
Old Jun 2, 2012 | 09:05 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
You got the frog leg bonus! Haha.. Congrats man she looks so sleek without! Did you use Goof Off to rub the stick tape off after you fished the bsm's off? Really looks gorgeous
Old Jun 2, 2012 | 09:06 PM
Silverback51's Avatar
Silverback51
Yep, looks much better without them.
Congrats on getting the BSMs off - car looks good either way, but in all honesty, I do like the BSMs on the car.
Old Jun 2, 2012 | 09:08 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Nice job! However I am also interested to know how you get the remaining residue off without scratching the paint, etc. Looks like a lot of left over adhesive, etc.
Old Jun 2, 2012 | 09:19 PM
MG RED 99's Avatar
MG RED 99
Old Jun 2, 2012 | 09:27 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
633K's Avatar
633K
Cruising
A heat gun and my thumbs. That's how I earned the blisters. Worked really well. Then the rest came off with some clay bar, cleansing wax, and rubbing alcohol. Then I waxed the affected areas.
Old Jun 2, 2012 | 09:29 PM
FormerlyFiero's Avatar
FormerlyFiero
Oldtimer
Mine's next! I have some Permatex Decal & Adhesive remover and some 3M adhesive remover (somewhere).
Old Jun 2, 2012 | 09:31 PM
1BADLS3's Avatar
1BADLS3
3M Adhesive Remover works WAY better than Goof-Off or Goo-Gone.
I know, I have de-badged many cars/trucks.
Old Jun 2, 2012 | 09:38 PM
tbrent's Avatar
tbrent
Holy WOW You used a heat gun! You're too kewl for skewl then.. I couldn't bring myself to do that.. lol.... I did use the goof off in a spray can when I did mine. I sprayed all along the bsm's top side real good to saturate the stick tape behind then took the fishing line and got my saw on while wearing mechanic gloves... when I got to the point where they were removed and had stick tape still stuck on the side of the car I just sprayed the goof off directly on and rubbed with gloved hands till I gathered little ***** of gunk and before you know it wallah.. A good wash and she looked great. Seems your method worked perfect too as your paint looks fantastic!
Here's the link I used from forum member Jason if anyone doesn't quite have a cahonas 633k does..
http://forums.corvetteforum.com/c5-g...them-pics.html
Old Jun 2, 2012 | 09:43 PM
papafrancisco's Avatar
papafrancisco
Excellent! Is there any discoloration between the paint behind the BSM and the rest of the body from sun, weather elements, etc?
Old Jun 2, 2012 | 09:49 PM
3whit's Avatar
3whit
Looks great,That as one of the first things I did when I got my Vette .
Old Jun 2, 2012 | 09:51 PM
PHIL MEMPHIS's Avatar
PHIL MEMPHIS
Pretty soon mine will be the only C5 with BSM'S. Good thing is they look great with or without.
Old Jun 2, 2012 | 11:31 PM
Dixiecrat's Avatar
Dixiecrat
I guess to each their own, you did a good job and car is beautiful, but I like the BSM.
Old Jun 2, 2012 | 11:40 PM
03 A/E Coupe's Avatar
03 A/E Coupe
Looks better with them gone.
Nice Coupe !
Old Jun 3, 2012 | 12:03 AM
Qwik01's Avatar
Qwik01
Looks cleaner!
To BSMs Removed
Old Jun 3, 2012 | 12:16 AM
Johnson 92's Avatar
Johnson 92
C5 of the Month 6/13
Old Jun 3, 2012 | 12:27 AM
Virtual Geezer's Avatar
Virtual Geezer
I'm one of the fortunate ones -- I think he C5 looks great with or without them. To each his own.
Old Jun 3, 2012 | 12:29 AM
633K's Avatar
633K
Cruising
No discoloration, 99.8% of people would never be able to tell that the BSMs were ever there. There is a tiny barely noticeable mark along where the top of the moldings were. I know it's there and even when I'm looking for it I usually can't see it. It's nearly impossible to spot.
Nice Coupe !
Thanks for all the compliments.
