E-Code Headlight Question
Old Jun 5, 2012 | 08:49 PM
PhilsFRC's Avatar
PhilsFRC
Default E-Code Headlight Question
Bought a set of e-code C5 lights that are missing the rubber boots on the back that seal the bulb. GM P/Ns are 16524063 and 4064. Bosch reflector number is 1 307 022 109. QUESTION-does anyone have a set lying on the bench where they can take a close look at the black rubber (sort of) doughnut seal on the back? Will probably have a p/n cast in it. Need that number to call Bosch USA. Not available as a separate part from GM. TIA.
Old Jun 6, 2012 | 07:38 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
Have a set at home. I'll check and post numbers for you tonight.
Silverbird
Old Jun 6, 2012 | 09:10 AM
PhilsFRC's Avatar
PhilsFRC
Default E-Code Boots
Thank you very much. Again, I've found that German stuff is typically VERY carefully marked, so it will probably (I hope) have the number cast into it. Probably begins with 1 307 .... PM me when you get a chance to take a look.
Old Jun 6, 2012 | 05:04 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Molded into the rubber boot on both lh & rh lights.
"BOSCH GERMANY 1300508007"
Hope this helps!
Silverbird
Old Jun 6, 2012 | 05:07 PM
PhilsFRC's Avatar
PhilsFRC
That's the KEY. Thanks very much--now to find it.
Old Jun 7, 2012 | 02:28 AM
Guilty in Chicago's Avatar
Guilty in Chicago
Guys, are these Hella E Codes you're talking about? I replaced the flashlights Jeep calls headlights on my Wrangler and love them, and was thinking bout doing the same for the vette. Also, what bulb are u using? Thanks
Old Jun 7, 2012 | 02:33 AM
DeeGee's Avatar
DeeGee
The T84 (euro) and T85 (UK/Japan) headlights use H4 dual filament bulbs
To E-Code Headlight Question
