Bird Poo strikes again!
Old Jun 5, 2012 | 09:05 PM
Greekg91's Avatar
Greekg91
Default Bird Poo strikes again!
I have an '00 C5 that I try to keep in very good condition. However, before putting it away for the winter (last year) I over looked a small area by the rear fender where a bird pooped on and it was left for a good 3-4 months untouched until I brought it out for the 2012 spring/summer year.
Once I realized that it was there, I washed, waxed and tried to polish the area where the poo was and it left a "stain" that is visible only if you look closely, but any Vette owner knows that knowing of its presence just drives you crazy.
Can anyone give me any advice how to remove the stain without damaging the paint job?
Thanks in advance!
Old Jun 5, 2012 | 09:09 PM
baxsom's Avatar
baxsom
wet sand
Old Jun 5, 2012 | 09:11 PM
Greekg91's Avatar
Greekg91
Originally Posted by baxsom
wet sand
What exactly do you mean by "wet sand"?
Old Jun 5, 2012 | 09:32 PM
_r2h's Avatar
_r2h
Depends on how far it went through the clear coat. You should be just be able to start with a mild compound then move up to a moderate if it doesn't work. Same thing with your pad, start off with a mild pad and move up to a more moderate pad. Keep in mind the clear on corvettes is very very strong and may require a little more tough love. Autopiaforums is a great place for info.
Old Jun 5, 2012 | 09:38 PM
Greekg91's Avatar
Greekg91
THanks r2h. What kind of compound do you/would you recommend? I have tried stuff like Turtle wax bug/tar remover and also a scratch/scuff remover..both with negative results.
Old Jun 5, 2012 | 09:48 PM
Z06Durham's Avatar
Z06Durham
Exactly what was said above. I'd be hesitant to wet sand if you're able to use a dual action polisher to pull it out
Old Jun 5, 2012 | 09:55 PM
_r2h's Avatar
_r2h
Check out this chart. I keep Prima Amigo, Prima Swirl, 3M Scratch removing, 3M Rubbing compound on hand. I also use Lake Country buffing pads, the blue/green/orange pads. My rule for paint resto is to start with your mild items and move up to your more aggressive items.
I'd be careful with the bug/tar remover. I had someone at work scuff their clear coat, and had to fix it for them. (I'm a medic, not a body shop professional btw).
My process would be to wash the area well, clay bar with mild clay, step up to a more aggressive clay (paint will need to be polish after as the aggressive clay's usually scuff the paint), try Iron-X if the material has an iron appearance, then move to polish/rubbing compounds.
Old Jun 5, 2012 | 10:00 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I use either Menzenra SIP or meguires 105 to get out those little issues and start with an orange pad and go to yellow if I need to
Old Jun 5, 2012 | 10:43 PM
onspeed's Avatar
onspeed
I'll just say that I had bird poop that was on the paint for just like a week or so. Menzerna SIP + orange pad did not get it out.
Going to try Meguiar's m105 with a foam wool pad and see if it does anything. This was suggested to me by a forum vendor over in the detailing section.
If that fails, I'm not going to worry about it. If it were a garage queen or weekend car it might bug me, but I've come to accept that **** will happen to it when using it as a DD.
Old Jun 5, 2012 | 10:49 PM
jrose7004's Avatar
jrose7004
Compound, clay bar and wax.
Old Jun 5, 2012 | 11:15 PM
Aerovette's Avatar
Aerovette
I have read a few posts noting the hardness or toughness of the clearcoat, but I have read as many that say it is dangerously thin. How many "swirl removal" sessions before you go through it?
Old Jun 6, 2012 | 06:34 AM
dougbfresh's Avatar
dougbfresh
2000 grit wetsand of the area then buff with a mild compound. If the bird poop was on that long, it's probably etched the clearcoat pretty deep. Had to do it on my hood after only a few hours in the sun, luckily when I did the hood, it got a LOT of clear on it.
Old Jun 6, 2012 | 09:08 AM
Good luck - post back up what you ended up doing and how it turned out.
Old Jun 6, 2012 | 09:14 AM
theheartbeat's Avatar
theheartbeat
Take to body shop slip the body guy a $10 and five minutes later your done.
Old Jun 6, 2012 | 09:57 AM
dougbfresh's Avatar
dougbfresh
And the $10 guy messes up your car, what do you think he'll do about it?
Old Jun 6, 2012 | 10:09 AM
theheartbeat
yea maby at the local Maaco. If you dont have a close body shop guy you are sol.
Old Jun 6, 2012 | 11:19 AM
Vettmann17's Avatar
Vettmann17
To Bird Poo strikes again!
Old Jun 6, 2012 | 11:46 AM
dadaroo's Avatar
dadaroo
Vetteman77, that was great.
Old Jun 6, 2012 | 12:32 PM
MGP1's Avatar
MGP1
2020 C6 of the Year Finalist - Modified
Don't forget about the bird!
http://www.youtube.com/watch?v=9sjI-2xTfTg
Old Jun 6, 2012 | 12:39 PM
Greekg91's Avatar
Greekg91
Thanks for the feedback, all. Vetteman... Thats too funny. I will do some research during the next couple of days and hopefully by the weekend, I will have some sort of positive outcome.
