Z51 Package questions
Old Jun 8, 2012 | 09:41 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Originally Posted by c4gone
No need to be rude im just saying.i know it was an option on the others but standard on the frc.i don't see y ur being rude.just when u said it.pulled harder and cornered better the first thing i.thought is frc.since i have one ..that's why.but geese sorry to bother u
You're right and I apologize. I just felt pretty insulted that you'd think I might be too stupid to know the difference between a coupe and an FRC.
Again, my apologies.
DSTURBD
Old Jun 8, 2012 | 11:12 PM
c4gone's Avatar
c4gone
I didn't.think u were too stupid.i don't make assumptions.i was just throwing out my.knowledge.
Old Jun 9, 2012 | 02:29 PM
woodman300's Avatar
woodman300
St. Jude Donor '15
Originally Posted by Zr-1Mike00
Here is a listing of all the options codes... If you look inside your glove box you will see the options that it came with from the factory on a rectangular white sticker... Z51 is an option code and if the car was build with it, it will be displayed there. I also believe there is a website where you can plug your VIN in and it will tell you what options the car has but I am not sure of what the site is. But try here for the options codes:
http://home.fuse.net/corvette/rpo.htm
here is another link to look at. it has info about all the corvettes. some info may not be completely accurate though because some of the engine specs were not correct
http://www.vettefacts.com/C5/C5Main.aspx
