Hello from a new guy
Old Jun 13, 2012 | 11:53 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Originally Posted by Terry T
Ok I finally pulled the codes. I didn’t know that there were so many….This is the whole list that it pulled up. Hope you guys can help out…..Here it goes.
28-TCS C1226H
28-TCS C1233 HC
28-TCS C1255H
28-TCS C1281H
28-TCS C1286HC
28-TCS C1291H
28-TCS C1293H
40- BCM B2723 H
60- IPC No Codes
80- Radio No Codes
99 HVAC B0361 H
99 HVAC B0441 H
HO- LDCM B2282 H
HO- LDCM B2284 H
HO- LDCM B2264 H
HO- LDCM U1064 H
HO- LDCM U1096 H
HI - RDCM B2283 H
A1- RDCM B2285 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
BO- RFA U1255 H
BO- RFA U1096 H
BO- RFA U1064 H
BO-RFA U1016 H
BO- RFA C2100 H
BO- RFA C2105 H
BO- RFA C2110 H
No More Codes
The H codes are history and can be cleared. The others may still be active. Check the 'stickie' at the top of this forum page. There is a chart of all code and what they mean. Then you can determine if you want to clear them or have someone take a look to see if there is a current issue. It will give you a good idea as to why you are getting some of the DIC errors. Zuti
