Hello all, I’m new to the C5 world. I have owned C4’s in the past. I have just purchased a 98 C5. It seems to be all stock. Got a really good deal on it. It runs and drives great. It has messages on the cluster that reads “ traction control” “ABS” “tire air sensor” that always flash. I can hold down the reset button and they go off but soon as I kill the vehicle and restart they all come back on. What should I do???????
welcome.
does it have aftermarket wheels?/tires bigger than stock? or smaller diameter in the rear?
possibly had the tire pressure sensors removed, if not they could be bad.
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
First off welcome to the forum! I've seen all of these errors. I also have a '98. The tire pressure sensor may be the tire sensor's batteries are getting low ( there is a fix if you search the 'tech' forum). The abs and traction control may be a dirty or faulty sensor in the brake assembly. Get all of the codes from the DIC, write them down and then clear them and see which ones return. Check out the 'stickie' at the top of this forum page (weights,measurements, etc) for all kinda of info regarding C5 issues, clearing codes, fixes for common problems, etc. It's a great car, fairly easy to work on and very reliable. Have fun and post some pics. Zuti
Ok I followed this and it didnt give me any codes. It did not turn off the warning messages.. I did it like 5 times with no luck.......
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button (for 5 sec) to turn off any warning messages
3) Press and hold "options" button and
4) While holding "options", press "fuel" four times within a 10-Second period.
Ok I finally pulled the codes. I didn’t know that there were so many….This is the whole list that it pulled up. Hope you guys can help out…..Here it goes.
28-TCS C1226H
28-TCS C1233 HC
28-TCS C1255H
28-TCS C1281H
28-TCS C1286HC
28-TCS C1291H
28-TCS C1293H
40- BCM B2723 H
60- IPC No Codes
80- Radio No Codes
99 HVAC B0361 H
99 HVAC B0441 H
HO- LDCM B2282 H
HO- LDCM B2284 H
HO- LDCM B2264 H
HO- LDCM U1064 H
HO- LDCM U1096 H
HI - RDCM B2283 H
A1- RDCM B2285 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
BO- RFA U1255 H
BO- RFA U1096 H
BO- RFA U1064 H
BO-RFA U1016 H
BO- RFA C2100 H
BO- RFA C2105 H
BO- RFA C2110 H
