Greetings, I'm having problems mainly when car is cold and ONLY when going into 1st Gear. I've done the Ranger method for fluid change with Dot 4 fluid.
Once I get it into 1st gear.......ABSOLUTELY NO problems going into 2nd-5th gears. No slipping, no miss shifts through FULL accelleration etc... Only when coming to complete stop and trying to go into 1st is the problem. Even when warmed up I have to push in clutch....wait a couple of secs and slowing ease into 1st. If I try to put it in normal speed it will grind.
Any insight is appreciated. BTW, 70k miles on OEM clutch '02 Z.
If it were the clutch, you should be having problems with more than just 1st gear. The fact that you're only having problems with 1st gear, though, makes me think it's a tranny issue, or hopefully just a misaligned shifter.
Actually, that sounds more like a synchro to me. Mine is tough in reverse, but I think it just needs the shifter adjusted. Does not grind, just hard to get in sometimes.
Thx for reply guys. What led me to believe it was a clutch issue is.....if I step on clutch and and try to go into first "normal speed" it would grind. BUT if I step on clutch and literally count to 3 and slowly push to 1st...it goes right in.
I was thinking the flywheel still spinning due to clutch slippage and as I waited few seconds it would bite and slow down enough to engage without the grind.
Then what leads me to believe its NOT the clutch is I have ZERO problems running through 2nd through 5th gears even at WOT.
i have the same problem with 4th, if I try to shift at 2500 rpms or higher tranny grinds but if I let the rpms drop it goes right in smooth, Got no idea what the problem is either
That def. sounds more like a synchro problem. I used to have a single turbo 3rd Gen Rx-7 that was notorious for 5th gear synchro probs. Just like you if you wait a few secs for RPMs to drop, it would slide right in.
My problem is not really related to RPM, rather at idle when I try to go into 1st without waiting 3 secs it will grind.
Maybe you're just a little too anxious to get it into first gear as soon as the clutch pedal starts depressing. I know my tranny is sometimes "notchy" going into first (especially when cold), but it never grinds ... but I always wait a few seconds after fully depressing the clutch to put it in 1st gear.
It could be a weak 1st gear syncro ... might try changing tranny oil and see if that helps.
Can you put it into 1st gear without grinding as you are slowing down? Try putting into 1st gear when you're at 5~8 mph. What's it do? That's a good syncro test.
mine just started to do that in reverse.... you feel it is not QUITE in, and it makes a slight grind noise, but goes in.
Mine a couple times, has had an issue where even after taking it out of R that it still wants to move back when I let the clutch out. I push the clutch in a few times and it's ok.
Hard to get it into first may be normal, but grinding is not normal.
Grinding is NOT normal. Easiest thing to do would be to make sure your shifter is correctly aligned. After that you'll be looking at some kind of transmission damage, likely synchro.
I like to do a rev test to make sure the disk is not dragging and the clutch is fully disengaged by pushing clutch pedal to the floor and revving it up in gear making sure the car doesn't creep forward. A weak master cylinder with blow by is a possible cause, hope this helps.
I have that in reverse.... kinda. I have it in reverse, and when I take it out sometimes it will still creep backwards when I start letting the clutch out.
