2001 c5
Old Jun 14, 2012 | 07:00 AM
Dutcharue's Avatar
Dutcharue
1st Gear
Default 2001 c5
2001 C5 just shuts down no codes other than low voltage, new battery, Dealer doesn't know what to do .HELP
Old Jun 14, 2012 | 08:13 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Man that could be any number of things, but you say it just shuts down and gives a Low Voltage. Have you checked the alternator? Is it putting out? It could be a grounding issue. Also is it intermittent or all the time? The dealership should be able to check the electrical system.
Old Jun 14, 2012 | 09:15 AM
CatCam's Avatar
CatCam
Clear out your your DTCs.....The next it dies,,, immediately check and write down ALL the DTC without changing the position of the ignition switch.
I would guess a grounding issue OR an ignition issue.
Here is a link on the grounding:
http://forums.corvetteforum.com/c5-t...tion-long.html
Here is a link on the ignition:
diagnosis
http://forums.corvetteforum.com/1568186703-post64.html
removal
http://forums.corvetteforum.com/1571067145-post107.html
repair procedure
http://forums.corvetteforum.com/c5-t...ch-repair.html
To 2001 c5
