Help deciding next mod
I've taken care of my rearview mirror problem with the help of Marc over at Vettenuts. My new mirror arrived yesterday, I just need the time to install it.
I have new plugs, wires, and poly bushings on the way from GM Parts House, so again, once I havce the time to install, I'll have my tune-up completed and will have finally gotten rid of the annoying squeaks from front and rear once my jacking pucks arrive from Southern Car Parts.
This takes care of the minor problems I was having (other than the CarToys fiasco), so now I'm looking at spending the last of this month's car budget on some equipment upgrades with a roughly $300 limit, give or take a few dollars. My 2000 coupe is strictly stock other than the aftermarket alarm & stereo system. My choices are:
Brake rotors & pads- Brakemotive drilled/slotted rotors & either Hawk or GM ceramic pads (This would lead to C5/Z06 calipers & steel braided brake lines in the next couple of months, so would wait for install until I had all pieces ready to go on)
C6 shifter- GM Parts House special - Current favorite, but an MGW in place of C6 seems to be the weapon of choice.
C6/Z51 sway bar/end links- GM Parts House Special
SLP Blackwing CAI (not interested in a VRAM atm)- Vendor tbd
None of the current equipment that these items would replace is in any danger of failing, I'm just looking to upgrade. Which of these do you think I would get the most enjoyment out of and should be my next step? Feel free to suggest something I might have overlooked on this list.
Edit- Wanted to thank whoever posted this: http://www.amazon.com/Flexible-Socke.../dp/B000RB31YO
I ordered this extension at the same time I ordered the new plugs and wires so I can get to that nasty #7 plug without too much fuss. I also have an oil filter magnet & magnetic drain plug on the way for my upcoming oil change. First one since I bought the car.
