Tpms sensor locations??
Old Jun 27, 2012 | 12:23 AM
Tyler_RN_EMT's Avatar
Tyler_RN_EMT
Default Tpms sensor locations??
Hello just bought a set of thin spokes to replace my painted wagon wheels. I'm going to have my wagon wheel tires swapped onto the thin spokes as well as the Tpms sensors from the wagon wheels into the thin spokes. My question is does it matter if they go into the same location on the car? In other words can the Tpms sensor that was on the left rear be placed on the front right for example? Or do they have to go back the same location?
Old Jun 27, 2012 | 01:35 AM
Ona mission's Avatar
Ona mission
St. Jude Donor '14
They can be re-programed,you need a strong magnet, I haven't done
it but
http://www.youtube.com/watch?v=vOM96f3Iy6E
I hope the link works...
Old Jun 27, 2012 | 02:21 AM
DeeGee's Avatar
DeeGee
When you train the sensors all you're doing is telling the car which sensor is at which corner. If you put the sensor back on the same corner there's no need to retrain. You can switch the sensors around if you wish, although there's no advantage in doing that. If you do you need to retrain them.
Old Jun 27, 2012 | 02:39 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
To make things easy, Have the tire shop install the sensors on the same corner they came off of. As said above you can retrain them if needed, If they work now I would just have them installed on the same corner.
Mr.Bill
Old Jun 27, 2012 | 07:42 AM
Sonny71's Avatar
Sonny71
Oldtimer
Mr.Bill
Old Jun 27, 2012 | 07:52 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Like already stated, have the tire shop switch them wheel for wheel. When I put on my C6 Z06 wheels, I marked each box with the new wheels and I marked each wheel and tire ( I took the tires off the car and took them to the tire store. If you take the car in, just tell them to do it.
Old Jun 27, 2012 | 07:59 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I did the same thing. I switched from the wagon wheels to thinspokes. I swapped the sensors to the new wheels.
Like others have said, It would be easiest if they just keep each sensor in the same position it was on the car. Then there is no need to relearn them.
However, it is not a big deal to retrain them if they are in different positions. It only takes about one minute. By selecting a sequence of buttons on the DIC it goes into training mode. Then holding a magnet against the left front wheel near the sensor until the horn beeps, move to the right front do the same until it beeps, then right rear, and finally left rear. Done.
Old Jun 27, 2012 | 08:19 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Tire shop should have no problem putting sensors in the same wheel position they came from.
Old Jun 27, 2012 | 08:20 AM
jrose7004's Avatar
jrose7004
I'd just make sure when you installed the new wheels that the sensors were where they were before. It would be easier on you that way.
Old Jun 27, 2012 | 10:35 AM
Tyler_RN_EMT
Thank you everyone! I will just tell the shop to put them back in the same locations!
Old Jun 27, 2012 | 01:27 PM
jim993's Avatar
jim993
I have retrained mine and then later changed to new sensors when the old sensors were about 12 years of age.
I followed the directions in the FSM, used a magnetic parts dish for the magnet. Worked fine.
Old Jun 27, 2012 | 01:35 PM
171soon's Avatar
171soon
This is what I'm wondering. I will have 2 sets of wheels, one of which will be used only occasionally for track. Once I've programmed them, no matter if they've been sitting around off the car for a couple months, they'll still be able to 'phone home' when I put them back on?
Old Jun 27, 2012 | 02:58 PM
DeeGee's Avatar
DeeGee
Tricky if you use 2 sets. The sensor also has a code so it learns the last set you programmed
Old Jun 27, 2012 | 03:30 PM
171soon's Avatar
171soon
Damn, that's what I was afraid of. I am going to check in over at the roadracing forum to see what guys do about that. I feel like it would be good to have the sensors on at the track as well as street... Thanks for the info
Old Jun 27, 2012 | 05:06 PM
QCVette's Avatar
QCVette
It is not a big deal. It will take a lot longer to swap the wheels on the car than to retrain whatever set you are putting on. It only takes about one minute to do and is easy.
I have a couple of sets that I swap between cars and it is simple, easy, and quick. Don't worry about it.
Old Jun 27, 2012 | 07:19 PM
92GA's Avatar
92GA
Oldtimer
You will most likely have to replace the O rings on the sensors. I don't remember what # they were but somebody on here should know. You can buy them any place that has an O ring selection. You will need 1 per wheel. I used a little stainless wire brush and some wd40 to clean the stems up before I removed mine.
Old Jun 27, 2012 | 09:33 PM
QCVette's Avatar
QCVette
I found some information about the Orings I used on my '99 sensors.
I got the Orings at Home Depot. There is a section with a lot of small o-rings, seals, connectors, etc. In that section I found a clear plastic small rectangular container hanging on the wall. The container is about 1" x 1" x2.5" and has 10 o-rings in it. I don't remember the cost, but I think it was only a buck or two.
The information on the paper liner inside the container is as follows:
Danco is the brand.
It says:
Repair
#9 O-Ring
5/8" O.D x 7/16" I.D x 3/32"
10 O-Rings Enclosed
#96726
On the side the SKU # is 3715596726
When I did mine i just removed the old O-rings and put the new ones in the same groove. Be careful taking the old ones out. They have been seated in the groove for years and are stuck. With a small blade or pick you can get the o-ring to start coming up in one section and pull it out. Be careful not to scratch the seal surface in the groove if you use a tool.
On the wheel, I just cleaned the inside surface where it sits.
I was concerned on how tight to make the nuts. I found the value on the forum with a search, but I don't remember it anymore. I think the 2000 and older take one value and the 2001 and newer take another torque value so make sure which torque value you use. I think the values were 106 in lbs and 35 in lbs, but I don't remember which is which or if those are the right values.
The sensors have been working and I have not had any air leaks in about 3 years.
Good luck!
Old Jun 27, 2012 | 11:44 PM
Put them back in the same location and you won't have to reprogram them. Otherwise, it's a five minute job tops with a good magnet.
To Tpms sensor locations??
