Wheel/tire question
If you want 18x9 and 18x10.5 for front/rear wheel sizes, what are the proper tire sizes?
Using those tire size calculators, the sizes that are "proper" seem to be either non existent or ridiculously expensive (I assume due to the fact that they aren't common sizes): e.g. 265/35/18 and 295/35/18. The overall diameter doesn't seem to match the stock sizes diameter?
Stock: 25.7"/26.7"
265/35/18 & 295/35/18: 25.3"/26.1"
In order to reach stock sizes.. you'd need:
275/35/18 & 315/35/18: 25.6"/26.7"
But it seems no one runs these sizes for 18/18? I also don't understand how the width of the tire should be adjusted if you choose between say 18x8.5 or 18x9 or 18x9.5 front wheels. I'd assume that the larger the width the less side wall you have?
What am I misunderstanding here? I need new tires this summer and I'm thinking of getting new rims... I think 18x9 and 18x10.5 yields the best value (factoring in price of tires.. the looks and the impact of weight on performance).
I've been running these tires sizes for over 4 years and haven't had one issue
So in conclusion:
As long as the tire diameter isn't too far off from stock, and the difference of tire diameter between front and rear is close to stock, everything else is fair game.
So in conclusion:
Stock has a 0.7"-1.0 larger rear tire. Try to keep your rear tire at least 0.5" larger in diameter.
Other than that you can run what ever sizes you want (as long as it fits in the wheel well
)Try to keep stay as close to the overall diameters as best you can... so that your wheels don't look too big, or too small in the wheel well. Also to keep your speedometer reading accurately.
When I went to a 19/19 combo I increased the overall diameter by 0.2" in front and rear. It really helped fill in the large wheel well a little. At the same time I maintained a 0.7" larger rear tire (same as stock Z06). 275/30/19, 305/30/19.
I would ask guys to look at their 18/18 combo's to see what sizes they are running, and see if it looks right to you.
I think most people are running a 275/35/18, 295/35/18. Lots of options on those sizes. A 305/35/18 rear would be even better. I think only Nitto makes that size though.
Toque
