Quick question - brake housing bracket
Old Jun 30, 2012 | 03:52 PM
nathaliev's Avatar
nathaliev
Default Quick question - brake housing bracket
My husband is outside changing the breaks/rotors
I just got home and he asked me to check online about this part (guess he's having a technical issue...)
He said he needs to know BOTH of these pieces are supposed to move up and down or only one side?
He referred to this part as a brake housing bracket.
Nat
Old Jun 30, 2012 | 04:02 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
That looks to be the caliper guide pin and it will move when the brakes are apart like that. If one side doesn't then it is stuck. Good time to change them if he has time. He can check with Gene at gmpartshouse and get a new set or maybe even check with local Advance Auto or Autozone stores.
Jim
Old Jun 30, 2012 | 04:11 PM
nathaliev's Avatar
nathaliev
Thanks!
So we can order just the pins right?
Old Jun 30, 2012 | 04:21 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I just recently bought a set from Gene for the brake swap I am currently doing also, and it came with new pins, bushings, and bolts to hook it all up.
Old Jun 30, 2012 | 08:37 PM
CHJ In Virginia's Avatar
CHJ In Virginia
BOTH of those pins need to move freely for the brakes to operate properly. They are called sliders. If one is stuck, you can probably use a pair of channel locks to work it loose by twisting back and forth. If it is really stuck, use some heat- a propane torch or similar to help loosen it up for removal. Apply heat to the body of the bracket in the area that the pin moves in. Use some solvent to clean both before reinstalling. Use high temp silicone lube - available at any auto parts store - to lube pins and bores. They should slide in and out easily.
Old Jul 1, 2012 | 08:57 AM
nathaliev's Avatar
nathaliev
thanks!
To Quick question - brake housing bracket
