What size resistors
Old Jul 1, 2012 | 06:18 PM
ttz's Avatar
ttz
Default What size resistors
What size resistors are needed for the low beams when switching to HIDs so they lower when turned off?
Old Jul 1, 2012 | 10:24 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
This is what you need.
http://shop.jwmotoring.com/product.s...8&categoryId=4
Old Jul 1, 2012 | 11:28 PM
ttz's Avatar
ttz
Hmm, thanks. Those are out of stock though. Any ideas on how to do a DIY version or what else might work? I know there are plenty of resistors out there for adding when switching to LED bulbs. Not sure whats needed though, 25w 6ohm, or something else.
Old Jul 1, 2012 | 11:32 PM
jrprich's Avatar
jrprich
I would bet that if you install a battery based relay wiring harness you will not need to add resistors to your lighting........and the harness will cost a lot less as well.
Old Jul 1, 2012 | 11:38 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Originally Posted by Mr.Bill
they're in stock. Plug n play no need to tap into the wiring.
To What size resistors
