HUD Color Question
Old Jul 5, 2012 | 01:19 PM
elopez1986's Avatar
elopez1986
Default HUD Color Question
Does anyone know if I can change the color of the HUD on my 2002 Corvette?
Just curious if I can make it into a blue bright LED.
Thank you!
Old Jul 5, 2012 | 01:21 PM
DIABL0's Avatar
DIABL0
Old Jul 5, 2012 | 01:39 PM
ronssito's Avatar
ronssito
no, but that's a great and original idea.
Old Jul 5, 2012 | 01:40 PM
mickey_7106's Avatar
mickey_7106
I think you can. I remember there was a thread in the norcal section about that service
Old Jul 5, 2012 | 01:41 PM
DeeGee's Avatar
DeeGee
Green (& red) is one of the best colors for night vision. No trouble during the day but be wary of changing colors that might stop you seeing past the HUD at night. White light, and any bright light kills your night vision.
Not sure if its a filter on the projector that selects the color.
Old Jul 5, 2012 | 02:32 PM
jrose7004's Avatar
jrose7004
I've never seen one any other color nor do I remember seeing anyone post a different color.
Old Jul 5, 2012 | 03:02 PM
Someone did ask that same question a while back. Not sure what ever came of that thread.
Old Jul 5, 2012 | 03:30 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Already tried it... well somewhat tried it. I didn't proceed too much on it though.
This is the one I do in the C6 Corvette... Factory color is green I changed this to Blue.
Old Jul 5, 2012 | 03:34 PM
DeeGee's Avatar
DeeGee
Thank you!
I had experience retro fitting night vision kit to a fast jet cockpit
Red is best but green works but bright is bad. This about sums it up:
To retain your night vision, a red light has been the traditional choice since before WWII when the military settled on red as the best choice. Recently, there has been a move to green and blue-green light, precipitated in large part by the military’s change to green, which itself has been primarily motivated by the increased use of night vision equipment. Which is really better? As it turns out, green light offers some advantages over red as a means to retain night vision capability. However, it isn’t cut and dried.
Total brightness, or illumination level, of the light has a potentially more significant effect on night vision retention than does the choice of red or green. Because your eyes are more receptive to green light, we gain better visual acuity at lower light levels than when using red light. Green also allows for differentiation between colors that red does not and the magenta used on aviation charts, for example, is readily readable under green light, not always the case with red.
Both reasons contribute to the fact that pilots and many others generally seem to prefer green
over red, it simply makes it easier to see and read in the dark cockpit. The potential problem is with the actual illumination levels we use, not the color of the light. The brighter the light, the more negative impact on night vision, both in our capacity to see and in how long it takes to gain back optimum night vision. This is true regardless of whether it is red or green.
Ideally, you want to use only as bright a light, red or green, as is necessary to perform your chores and no more. However, if you have a brighter light than you actually need, a brighter green light will generally have a more negative effect than an equally bright red light. Green or
blue-green has a greater capacity to adversely affect night vision because the eyes are about 100 times more sensitive to these colors, so even moderately too bight light can have a serious deleterious effect.
Another complication is that an individual’s visual acuity at low light levels varies quite a bit, so what would be perfect for one, might be too bright or too dim for another. In other words, without some means to vary intensity, odds are no light will be perfect. Bottom line is that red or green will both perform adequately, but what you really should be more concerned about is to avoid very high illumination levels, of either color, if retaining night vision acuity is your goal.
Old Jul 5, 2012 | 03:47 PM
elopez1986's Avatar
elopez1986
Very nice reply, DeeGee....
Old Jul 5, 2012 | 08:49 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
just to clarify on Andrew's post; he has changed them for the C6's; not for the C5's
market demand for the base C5 HUD upgrade is minimal
Old Jul 5, 2012 | 10:21 PM
Former Vendor
yep, c5 projector is different. I have heard folks say they have swapped out the c5 cluster and projector and put in a c6 one though... not sure how that came out though.
To HUD Color Question
