Tire Pressure Sensor Issue...
Old Jul 11, 2012 | 07:42 AM
Blue Thunder's Avatar
Blue Thunder
Cruise-In I Veteran
National Champs Gators 4 St. Jude '09
Default Tire Pressure Sensor Issue...
My left rear keeps indicating Low Pressure, yet I have checked it numerous times with more than one pressure gage and it is right where it should be.
Any thoughts on corrective so I don't have to stare at the pressure warning in the Info Center on the dash?
Thanks.
Mike
Old Jul 11, 2012 | 08:09 AM
Sonny71's Avatar
Sonny71
Oldtimer
How old is the sensor?
Old Jul 11, 2012 | 09:35 AM
Does sound like your sensor is on the way out. You can try retraining the sensors to the car - very easy and takes on a couple of minutes and see if that helps. If not, consider getting a new set of sensors.
Old Jul 11, 2012 | 10:24 AM
Grainraiser's Avatar
Grainraiser
I have the same issue. My right front either reads pressure is low or flat. I guess I will try to reset it. I figured the battery is gone.
Reggie
Old Jul 11, 2012 | 01:29 PM
Blue Thunder
Cruise-In I Veteran
Thanks all for the guidance. I will re-train first, and then replace if that does not work.
Original sensors....so maybe it's just tired.
To Tire Pressure Sensor Issue...
