I have basic bolt ons in my 01 Z now and im going to be purchasing a cam soon. The cam is a custom grind cam from Advanced Induction. The specs are 234/242 600/600 112 lsa. I also will be purchasing a fast 102. My question is will the fast 102 bolt right up with no problems and will the fast 102 work fine with the vararam. My power goals are 430-440. Here in AZ it may be a little less.
Thanks for the input in advance!
fast 102 may not fit too tight
the 234/242 600/600 cam may not be a good choice for stock 243 heads.
I have a custom grind in my LS1 F-body that is 235/241 598/609 on a 112lsa. Comp XER lobes.
The cam sounds NASTY, I could only imagine what it would sound like in my Z0 with LT's and stock Ti exhaust.
On the stock intake with a ported TB and Hooker LT's and a 3" Y-pipe and stock CB, 3.73's, M6 Car. I made 430rwhp.
I then swapped out to a FAST 102 and TS 96mm TB and a E-cutout.
On the stock intake the car was a TURD down low. The cam doesn't come in till about 3k RPM's and seemed to be chocked off about 6k.
After I swapped out to a PORTED FAST 102, the car just WOKE up. I can't believe how much more fun the car is to drive after adding the 102. I made 400ftlb of TQ at 2500rpm. That's unheard of in an LS1. Oh, all of this is through a pair of 241's!!!!!
A couple of things you should know. With the aggressive cam I had to swap out lifters. I installed Comp OE lifter, hardened pushrods, and a dual valve spring good to .650 lift from AFR w/titanium retainers. The car is dead reliable and starts right up. Runs good. Has good low in grunt right off idle. Very little cam surge.
I don't have any experience with the FAST 92mm that was just released, but that may be an alternative to the 102 if it doesn't fit under the hood.
Thanks for the info guys i think i have it all figured out its gonna be a slightly different cam and maybe a FAST 92. Im gonna start ordering parts this week ill post results later.
