Tie rods
Old Jul 15, 2012 | 11:44 PM
Dale002's Avatar
Dale002
Default Tie rods
Do C6 tie rods fit the C5? I have a set of new C6 and was thinking of installing them on the C5 since the C6 is now gone.
Old Jul 16, 2012 | 09:24 PM
Dale002's Avatar
Dale002
I found some info to my question. Supposedly.yes you can. The inner tie rod needs a flat ground in the outer diameter so it locks into the cradle of the C5, and doesn't turn when you tighten the nut.
Old Jul 16, 2012 | 10:25 PM
LT1driver's Avatar
LT1driver
the question to you is WHY???
Old Jul 16, 2012 | 11:55 PM
Dale002's Avatar
Dale002
I have a brand new set of GM C6 front and rear inner and outer tie rods that I came across for cheap last year. I just sold my C6 and I'm in the process of repairing a salvage 99 FRC with 100k. It need one rear outer tie rod and thought if they could be use,why not! I know many of suspension part are interchangeable. Wasn't sure about the tie rods,but now i know you can. The different in the rear is the cradle.
To Tie rods
