NEW! Urethane Engine & Transmission Mounts
Old Jul 19, 2012 | 11:44 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default NEW! Urethane Engine & Transmission Mounts
We are proud to release our newest upgrade for the LSx family!
Interlocking Urethane Engine Mounts for the Corvette C5/C6/Z06
MADE IN THE USA!!!
These urethane engine mounts are designed for a great balance between engine control and vibrations. They have been tuned for both street and track applications. Replace your stock rubber mounts for improved throttle response and reduced engine movement.
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Applications
* 1997-2012 Corvette C5/C6/C6Z06
* 2004-2006 Pontiac GTO
$165 - Urethane Engine Mounts C5/C6/Z06 (OEM Standard Height)
$165 - Urethane Engine Mounts (Shorter Version) C5/C6/Z06 (.360" Shorter)
$173 - Urethane Transmission Mount C5
$300 - Urethane Engine & Transmission Mounts Combo C5
*Dealers Welcome
0HinsonSuperCars
Former Vendor
As you can see in the below cut away image, the engine rides on the durable urethane. This is how we control engine movement while not passing every vibration in to the passenger compartment.
The inside of the mount is interlocked. Even if you found a way to damage the mount, the stainless interlocking design will keep it all together. The design is built with stainless steel, so they will not rust. They accept your factory nuts. This means there will be no emergency hardware store trips.
Old Jul 24, 2012 | 02:21 AM
Qweklain's Avatar
Qweklain
Out of curiosity, is it possible to get an under camera view of your engine & trans mounts at work similar to how Pfadt did their mount comparison to stock? I want to get new mounts and am not sure which to get, and that would be a great comparison to be able to see the two competitors at work!
Old Jul 24, 2012 | 11:31 AM
0HinsonSuperCars
Former Vendor
Sorry, we don't have a video. You can read a ton of reviews below.
http://forums.corvetteforum.com/c5-t...on-mounts.html
http://forums.corvetteforum.com/c6-t...on-mounts.html
http://forums.corvetteforum.com/c6-z...on-mounts.html
Old Sep 14, 2012 | 01:18 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Whats with the shorter engine mount?
Old Sep 14, 2012 | 01:56 PM
0HinsonSuperCars
Former Vendor
The shorter mounts are .360" shorter than our standard height mounts. They will lower your engine to allow for additional hood and cowl clearance. These work great for Corvette C5 owners who are installing the FAST 102 Intake Manifold.
Old Sep 21, 2012 | 01:27 PM
draggon007's Avatar
draggon007
i purchased the transmission mount,works great hassle free install..good product.
Old Sep 25, 2012 | 12:43 PM
0HinsonSuperCars
Former Vendor
Old Feb 5, 2013 | 11:44 AM
0HinsonSuperCars
Former Vendor
Engine mounts are back in stock!
Old Feb 5, 2013 | 01:27 PM
FLYNAVY30's Avatar
FLYNAVY30
does the shorter engine mount adversely affect drivetrain alignment or impose any increased wear and tear on the driveline components?
Old Feb 8, 2013 | 10:42 AM
0HinsonSuperCars
Former Vendor
We haven't experienced anything negative.
Old May 17, 2013 | 03:58 PM
0HinsonSuperCars
Former Vendor
Thanks for your orders!
To NEW! Urethane Engine & Transmission Mounts
