Front leaks
Old Jul 25, 2012 | 02:29 AM
RedRckC5's Avatar
RedRckC5
Default Front leaks
What kind of leaks are prone on the front of the car? I know differential and trans are in rear. I spotted a small spot on the front left side (driver side) underneath when I move the car. My friend checked it out and said possible steering fluid? Coolant tank is full so that couldn't be it.
Old Jul 25, 2012 | 12:50 PM
RedRckC5's Avatar
RedRckC5
Thanks for the info. It's kind of reddish, slimy fluid. At first, I thought it maybe ATF or DIF, then power steering, but now I think it may be the water pump. She has been running hot lately. 195-200 on highway and 230+ on stop and go. Do have a lower stat installed and have never seen these temps before.
Thanks again!
Old Jul 25, 2012 | 09:35 PM
dlind4's Avatar
dlind4
If it's the left front its probably the radiator. If the rad is stock the plastic ends crack. Mine is like this now and I'm waiting on a new dewitts radiator to come in. I at first thought it was the hose but on closer inspection the top is cracked and seeping. Just keep that in mind it might not be the water pump.
Old Jul 25, 2012 | 10:37 PM
RedRckC5's Avatar
RedRckC5
Yeah it's a stock rad. I'll check it this weekend. I do smell a hint of coolant smell. I guess I get to borrow my brothers ZR1. Lol! Thanks for the tip.
Old Jul 26, 2012 | 01:37 AM
RedRckC5's Avatar
RedRckC5
Hmmm...slight coolant smell when ac was on while driving on the freeway. Temp rose to 199 while accelerating to 70, but stayed at 190 during street driving.. Weird...
Old Jul 26, 2012 | 01:49 PM
RaiderNick's Avatar
RaiderNick
Originally Posted by 8VETTE7
I would not discount a coolant leak just because the surge tank looks full. A coolant leak that resulted in the level being noticeably down would have to be sizeable or going on for a long time. A water pump weep would be my first guess. Coolant or any other fluid leaks seldom drip straight down to the ground from the source of the leak. They typicallt fall onto a motor or accessory part, frame or suspension and travel for often some distance before they make a path to the ground. Suggest you find some way to get the car up in the air to be able to get under it and carefully inspect. If it were my car i would look carefully at the area under the water pump to start with.
Sometimes you can get a clue to what is leaking by carefully looking at the color of what makes it to the ground. For example the coolant is usually DexCool and that has a redish orange color.
I would agree. I had a similar issue and it turned out to be a water pump weep. This had gone on for a few months and I never saw any significant drop in the coolant overflow tank.
Old Jul 26, 2012 | 08:47 PM
RedRckC5's Avatar
RedRckC5
I guess time to shop for a water pump and possibly the radiator. Any advice? CC had them both at $199.99 each (stock).
Old Jul 26, 2012 | 10:33 PM
C5FORFUN2's Avatar
C5FORFUN2
Agree on getting it up in the air to see where it's coming from. The power steering is a possibility as well as trans fluid if it's an A4 from the cooler or lines.
Old Jul 26, 2012 | 10:40 PM
m6 c5's Avatar
m6 c5
Sure sounds like either a high pressure line for your power steering or the rack to me, coolant isnt really slimy...
Old Oct 14, 2012 | 10:55 PM
Jackman's Avatar
Jackman
I have a leak that I know is power steering. power steering fluid level keeps running low. It's not coolant. I had that leak already and changed my water pump. That problem solved.
But I can't pinpoint where this power steering leak is. Any ideas that can help me would be appreciated.
Old Oct 15, 2012 | 10:54 AM
m6 c5's Avatar
m6 c5
Have you checked your high pressure line
Old Oct 15, 2012 | 04:17 PM
Jackman's Avatar
Jackman
Default Front end leaks.
Thank you for the reply. I have looked under the car while on car ramps but can't pinpoint the leak. How do I check the high pressure line?
Old Oct 15, 2012 | 07:13 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
There is UV dye available for your engine oil and cooling system at any parts store. (different stuff for each of course). You can get that and then use a UV light to find the leaks easily.
At the rear of the windshield washer tank on the side, there is a rubber seal into which the low washer fluid sensor is pressed. That isn't a real tight fit and any wrenching around in that area will knock it loose. You might check that the sensor is seated fully. When I clean the drain utters on mine I almost always knock it loose. Just a touch does it.
Old Oct 15, 2012 | 08:03 PM
sonny557's Avatar
sonny557
Default Mirror
If you take a small telescoping mirror and hold it behind the water pump pulley and shine a flashlight behind the pulley you can see if the water pump is weeping. oops sorry just read where you have ruled out the coolant.
Old Oct 15, 2012 | 08:29 PM
Jackman's Avatar
Jackman
I will check that. I never use the washer fluid, don't even know it there is any in there. But I will check it anyway. But that won't explain my power steering fluid always running low.
Thank you for the suggestion.
Old Oct 15, 2012 | 08:33 PM
Jackman's Avatar
Jackman
That's o.k. You are just trying to help and I take all suggestions. But your right. I already changed the water pump recently and it's the power steering resevoir that keeps running low.
The leak seems to be more on the drivers side under the P.S. resevoir.
Old Oct 15, 2012 | 11:54 PM
m6 c5's Avatar
m6 c5
Well if your power steering is running low then you have a leak in the system somewhere. The two biggest problem areas are your high pressure line and the rack itself, I would start with cleaning up the mess with a good degrees-er such as simple green, I use purple power but that can etch paint so simple green is a safer choice. I would also pull the plastic loom off of the high pressure line so you can see if it is seeping out. If you dont clean up the mess thats down there already then its going to be very hard to pinpoint where it is coming from as it just gets everywhere, I made the mistake of just jumping to conclusions and ended up replacing the rack before finding out it was just a 15$ hose.
To Front leaks
Old Oct 16, 2012 | 10:26 AM
Jackman's Avatar
Jackman
Thank you. That makes a whole lot of sense to me. Sometime this week I will do just that.
Old Jul 27, 2013 | 02:27 PM
kenb538's Avatar
kenb538
4th Gear
Did you ever pinpoint the leak in the power steering line. I have a 2001 corvette and in the past year it has developed a leak in the power steering system. I have examined the car and it is difficult to see the source of the leak. Your experience may be helpful.
Old Jul 27, 2013 | 03:23 PM
Jackman's Avatar
Jackman
In my case I followed directions and cleaned the area with a de-greaser. I discovered my leak to be in the High Pressure hose. The hose was not expensive but the repair was a little difficult and took me over an hour. But replacing the hose did resolve the problem. No more leak.
