Has anyone tried these side air dam supports from a bunch of vendors? My side portions of the air dam sag at the corners, these are made of plastic, I doubt they hold up a sagging side air dam ? What do you think ?
I put a set of these on at the same time I put on a brand new set of side air dams on. They use the factory hardware and appear to keep everything pretty solid. Haven't had any issues to speak of. Not an expensive little piece of insurance either if I remember correctly.
I also use these, but I added some small (3/4" od) fender washers on the screws for added support. Before using these the end pieces would tear away at the screw holes. Now they last about two years (I scrape going in and out of our driveway).
OK, Well we've got 6 votes yes, they worked, 2 votes doubting their effect (I included myself). 2 votes saying they didn't work, 1 vote from the shade tree fix and 2 votes asking where to get them. I am holding a set I bought years ago and these are weaker than some of my cats toys.
My air dams sag right at the corners, and I'm not drilling a 1/8 hole in the bumper to put a screw into shore it up, so (By the way, putting a screw into the bumper seems like the most logical fix, but I can't do that) I was wondering how these little plastic thing will work on five year old air dams ? Crazy, how the tiniest problems can bug you !
In the time it took to type these two paragraphs, you could install both supports and see for yourself.
I was skeptical at first however I have been happy with them.
The corners will still scrape, however the support arms will help prevent the corners from pulling away from the fascia as the OEM screws fit through the hard plastic support brace vs. the soft flexible spoiler.
