[Z06] Console lighter help
Old Jul 31, 2012 | 10:10 PM
LowNSlow01's Avatar
LowNSlow01
Default Console lighter help
Hey guys,
I was hoping you can help me solve a weird issue. I had a flat, used the compressor in the rear to charge up my tire. I used the compressor for about 10 minutes and afterwards my console cigarette lighter did not work anymore. I had used it just earlier in the day to charge my iPhone. I did my research and changed fuse #1 (under passenger foot), no luck. I checked if a cable came loose behind the cigarette charger, nope its good. Then I got a volt meter and check voltage on fuse #7 (cigarette lighter under the flap, it read 11 volts, then checked fuse #1 and it read 1.2 volts. Can anyone please guide me on how I can fix this?
Thanks!
Old Jul 31, 2012 | 10:26 PM
bumble-z's Avatar
bumble-z
Was the #1 fuse replace with a 20 A fuse?
Are you using an aftermarket air compressor?
Try turning/twisting the plug into the outlet ?
It may be best to use the air compressor, directly off the battery with alligator clips?
Old Aug 1, 2012 | 12:40 PM
LowNSlow01's Avatar
LowNSlow01
- Fuse #1 was replaced with 20 A fuse from under the hood, one of the spares.
- Nope, I am using the OEM air compressor that came with the car.
- I tried different plugs and twisting it different ways, no luck.
- I will know for next time, figured since it was OEM and made as a cigarette lighter it would be fine.
Anyone else have any suggestions/ideas?
Old Aug 1, 2012 | 03:32 PM
waddisme's Avatar
waddisme
I have used my oem compressor thru the cig outlet for over 5 years for tracking with no issues. Now the one in the dash, who knows why it doesn't work.
Old Aug 1, 2012 | 03:50 PM
LowNSlow01's Avatar
LowNSlow01
Guess I just had some bad luck!
Old Aug 3, 2012 | 07:31 PM
LowNSlow01's Avatar
LowNSlow01
Anyone had this issue?
Old Aug 3, 2012 | 10:11 PM
71corv's Avatar
71corv
St. Jude Donor '08
I still have this problem. Used the lighter to run a small vacuum cleaner. Worked for a while, but not for about a year now. Haven't worried about it as I don't need the lighter. Would be nice to know what went wrong. Have checked fuses, replaced the lighter parts, checked all connections, etc. but it still does not work.
Gene
Old Aug 6, 2012 | 01:04 PM
LowNSlow01's Avatar
LowNSlow01
So weird, do you guys think it could be the thing that holds all the fuses?
Old Aug 7, 2012 | 04:23 PM
LowNSlow01's Avatar
LowNSlow01
Bump
Old Aug 7, 2012 | 04:41 PM
bumble-z's Avatar
bumble-z
Originally Posted by LowNSlow01
Bump
I thought for sure, an eletrical guru would have come to your rescue by now.
I'm terrible with electronics.
I would think that if you disconnected the connection from the back side of the console lighter.
Then run the same/proper size new wire from the fuse in the pass/side, fuse box to the backside of the cig lighter.
This would tell if it is indeed a break down of the original wire/harness?, that goes to the cig/lighter to the fuse box.
If the new wire shows failure too, I would inspect the wire & connection that goes into that fuse in the box
Old Aug 7, 2012 | 09:55 PM
71corv's Avatar
71corv
St. Jude Donor '08
bumble-z, thanks for posting the suggestion. Will file this for use this winter while I'm making repairs/additions to my car.
Gene
Old Aug 7, 2012 | 11:37 PM
orangeclaw's Avatar
orangeclaw
Mine wouldnt work for a while, I just changed both 1 and 7 fuses, started working again! Since you've done this... I'm sorry I cant be of more help.
Old Aug 8, 2012 | 12:30 PM
LowNSlow01's Avatar
LowNSlow01
My dad suggested I can connect the wire to another fuse that is not in use that is same power. I will try that and if not I will replace the wire like you said.
Old Aug 8, 2012 | 02:42 PM
bumble-z's Avatar
bumble-z
LowNSlow01,
I'm not suggesting to change out the wire I mentioned.
The wire would only be for a test, from the fuse box to the c/lighter.....
to see where your electrical problem is/lives.
To Console lighter help
