High pitched whistle
Old Aug 1, 2012 | 06:59 PM
Aerovette's Avatar
Aerovette
Default High pitched whistle
I have had this issue for quite some time and I cannot determine the cause. At full throttle just before the next shift (it's an auto) I hear this high pitched whistle almost like a waste gate sound. Once it shifts it is gone. There is no way to be under the hood and under load at the same time so I have to rely on guesses and forum member's experience. Any ideas? It is not speed related but is RPM related. At full throttle any other time, it is not present or not audible. It is at the 1-2 shift that I hear it. It may be from 2-3 as well, but I am not wound out like I am from 1-2. I tried recording it with my phone but the ambient noise is way too loud.
Old Aug 3, 2012 | 01:38 PM
Aerovette's Avatar
Aerovette
Wow, not even a guess ?
Have I stumped the forum?
Old Aug 3, 2012 | 02:08 PM
sean.b's Avatar
sean.b
have an aftermarket air intake?
Old Aug 3, 2012 | 02:42 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
If, unloaded, idle hangs a little high or is a little slow to return all the way down to idle, then I would guess you might have a vacuum leak. This might also explain why you get a whistle at high RPM's from it, although actual intake manifold vacuum is usually at its lowest with large throttle openings.
Just a guess, but maybe something to look for.
DSTURBD
Old Aug 3, 2012 | 03:07 PM
Corvette_Ed's Avatar
Corvette_Ed
This was my first thought.
Old Aug 3, 2012 | 03:40 PM
NukeC5's Avatar
NukeC5
I think it may be a vacuum leak at the intake. You would hear it squeeze by when the pressure changes during the shift. Its most likely happening on all shifts too, but not as noticeable.
Old Aug 3, 2012 | 11:47 PM
Aerovette's Avatar
Aerovette
The car is bone stock. I bought it with 13k on it so the problem has been around for a while. Now at 37k. How would I go about finding an intake leak and would a smoke machine find the vacuum leak?
Pitch get higher as RPMs climb.
To High pitched whistle
