Left Front Directional Bulb
Old Aug 2, 2012 | 07:20 AM
jersey68l36's Avatar
jersey68l36
Default Left Front Directional Bulb
My friend's '01 Keeps blowing the left front directional bulb. Does anyone knows if this some sort of generic C5 problem, or a matter of sorting out wiring for some sort of short? Theres also a battery drain problem going on, and my friend thinks they are related. Thanks for any comments.
Old Aug 2, 2012 | 08:18 AM
Corvette_Ed's Avatar
Corvette_Ed
Normally when you have a bulb going out continuously like that it's because you have a cracked housing and water is getting to the bulb.
Old Aug 2, 2012 | 09:42 AM
bumble-z's Avatar
bumble-z
Yes it's quite common for the front corners, turn sig/DRL housing to melt directly above the bulb (extreme heat) .
It melts to the point to where it ruptures completely through, allowing moisture / water penetration to drop onto the bulb... causing the bulb/bulbs to blow frequently.
There have been many posts/threads in this regards & different means to properly address the problems.
Old Aug 2, 2012 | 10:19 AM
Zmeister's Avatar
Zmeister
Yep....what they said!!
Mine pretty much blows the left bulb once a year. Each time I replace it I find moisture in the housing.
I just picked up some used, undamaged lights from a Forum member and will be swapping them out soon. I am expecting that this will fix my problem.
Good luck!!
Old Aug 2, 2012 | 11:16 AM
After washing the car, have him check and see if any moisture appears in the housing. If so, that's probably your culprit.
To Left Front Directional Bulb
