Steering wheel moan?
Old Nov 1, 2012 | 08:20 PM
1KLRTOY's Avatar
1KLRTOY
Originally Posted by onspeed
I sprayed WD40 onto the bushings at the firewall from the engine bay side and my squeak went away.
I used Boeshield T-9 seems to last longer than WD40 also spray from the inside as the lube seems to penetrate better from the top
Old Nov 1, 2012 | 11:30 PM
Qwik01's Avatar
Qwik01
Thats what she said.
Old Nov 2, 2012 | 10:08 PM
froggy47's Avatar
froggy47
Here ya go.
http://www.youtube.com/watch?v=pnyNZbMldIg&feature=plcp
Old Nov 2, 2012 | 11:57 PM
Choreo's Avatar
Choreo
Mine comes and goes over the past years. Never have found the cause - sounds like a rubber part not lubricated rubbing against another rubber part, but it will go away for weeks at a time on its own. Once it starts, it will be chronic for maybe a day or two, then it is completely gone?
Old Nov 3, 2012 | 12:11 AM
froggy47's Avatar
froggy47
My theory is that the parts are lubed when the car is built & over time/heat/cold/weather/water it gets dry & starts to moan & groan. Not sure why yours would come & go unless it's weather related. Mine came & stayed until I lubed it.
Old Sep 15, 2013 | 01:39 PM
froggy47's Avatar
froggy47
I replaced my p/s pump & still have the noise. Nothing wrong with pump. Has to be the steering column.
Old Apr 17, 2019 | 10:19 AM
killian96ss's Avatar
killian96ss
My 02Z is now making this annoying noise. It really does sound like a moaning noise very similar to the noise a PS pump makes when it's low on fluid, full of air or just failing. I've already confirmed it's not the pump and the sound is coming from the column area. The noise is non existent for the first 10 miles or so and only shows up after driving for a while. Before I start spraying lube everywhere mentioned above can anybody who has had "success" with this problem let me know what lube and lube points worked best. Thanks.
Steve
Old Apr 17, 2019 | 11:49 AM
lamaro88's Avatar
lamaro88
In for a response, as my car too has started to make some noise.
Old Apr 17, 2019 | 12:08 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Turn the radio up before driving
Old Apr 17, 2019 | 01:20 PM
turabo87's Avatar
turabo87
I've had this issue come and go. The last fix has worked wonders to fix it permanently. What I did to fix it was to accept the noise and embrace it in my heart.
Old Apr 17, 2019 | 04:30 PM
froggy47's Avatar
froggy47
I used non greasy lube spray can with one of those extensions (18") to shoot around the firewall engine side where column goes thru, fixed.
Probably I made a video, look for it.
Old Dec 6, 2020 | 11:46 AM
Mjd1935's Avatar
Mjd1935
1st Gear
Default This will fix it
Originally Posted by Ghost Vette
Been there: actually I found mine and fixed it. I always thought in was coming from inside the car around the column. It really is outside down at the fire wall and under the brake booster. you can spray WD40 or some kind of lubricate around the bushings and might just stop your problems. Good luck and hope you get it to stop. I did finally.
Get one of these long spray tubes for a spray can of silicone oil.
Amazon Amazon
​​​​​Guide the tube to the rubber firewall bushing under the hood. Push it into the gap between the steering shaft and bushing. Give it a couple of squirts. Go out and do some full turns of the wheel both directions and it should be gone. WD-40 will evaporate and the problem can come back.
