[Z06] Mantic Er2 FTW!!!
Old Sep 23, 2015 | 06:31 PM
  #41
Christian327's Avatar
Christian327
Default Mantic Er2 FTW!!!
Originally Posted by Scotty2000SS
I'd contact Geoff at Mantic if you have any questions. Send me a PM if you want his number
PM sent!
Old Sep 23, 2015 | 07:12 PM
  #42
Cheesecake 07's Avatar
Cheesecake 07
Originally Posted by Christian327
I am actually about to buy the Er2...This thread gives me even more confidence in the purchase. Installer said that all I need is what comes with the kit which includes bearing, pressure plate, clutch disc, flywheel and bolts...He said that he will order the oem cylinders, master & slave. Is that going to be okay? My car is pretty much stock and all I eventually want to add is just a honker/tune. Thanks for any input!
Yep..zachly what I did. Used fresh OEM hydraulics.
If your master is in good working order you'll be fine re-using it. I replaced mine because they aren't real expensive and pretty easy to put in.
That's great news. Thanks for the feedback
Anytime
Old Sep 23, 2015 | 07:44 PM
  #43
Christian327
If your master is in good working order you'll be fine re-using it. I replaced mine because they aren't real expensive and pretty easy to put in. Anytime
Awesome thanks for the input brother!
Old Sep 28, 2015 | 08:22 AM
  #44
Scotty2000SS's Avatar
Scotty2000SS
Was Geoff any help?
Old Sep 29, 2015 | 05:04 PM
  #45
Christian327
Was Geoff any help?
Extremely helpful! Pm sent
Old Oct 17, 2015 | 06:07 PM
  #46
azvrod's Avatar
azvrod
OK update: Mantic was installed and ran in 1/2 mile roll on's on Oct 3. First impressions: Pedal feel is firmer than stock, and release point is further from the floor. Shifts are clean and confident (used to have concern about going into 5th, vs 3rd..or heaven forbid reverse). I do have an an MGW short shifter. So far, seat of the pants tells me its hooking up better..but I do have a traction issue (tires).
KJ
Old Oct 17, 2015 | 07:25 PM
  #47
Scotty2000SS
Originally Posted by azvrod
OK update: Mantic was installed and ran in 1/2 mile role on's on Oct 3. First impressions: Pedal feel is firmer than stock, and release point is further from the floor. Shifts are clean and confident (used to have concern about going into 5th, vs 3rd..or heaven forbid reverse). I do have an an MGW short shifter. So far, seat of the pants tells me its hooking up better..but I do have a traction issue (tires).
KJ
How much further from the floor? I've read about the high release point on a few other clutches.
Old Oct 18, 2015 | 09:40 PM
  #48
azvrod's Avatar
azvrod
You know, Its kinda subjective, but I would say about 3/4 of the way out(from the top)..vs about 1/2 way out for the stock clutch. So maybe about 3 inches from the top. Ill drive it tomorrow and try to pay attention and report back.
Old Jun 10, 2016 | 04:23 AM
  #49
CHRIS925's Avatar
CHRIS925
That's great news. Thanks for the feedback.
A friend of mine currently has the ER2 in his C5Z. He ran an 11.8x with consistent 1.6x 60fts at Sacramento Raceway. All he has done is longtubes and hoosier 245 drag radials. Still has the stock air box lol
225s*
