HVAC help!!
Old Aug 11, 2012 | 04:25 AM
_Wayne_'s Avatar
_Wayne_
Default HVAC help!!
I was doing the led swap and it was all fine until I plugged it in and smoke came out the back! Everything works fine except the back light LEDs which I put in but they all work fine if I hook a 9 volt up to it?!? Need help bc I leave for college Friday and would like to have this solved! I think it's something to do with the power board but I don't know!
Old Aug 11, 2012 | 08:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Are you aware that LED's are polarized? Put them in backwards and they either won't work or fry something. Guessing you might have crossed a solder path but the only way to know is to take it apart and look
Old Aug 11, 2012 | 09:07 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Sounds like you let the smoke of of it... Can't put the smoke back in I'm afraid.
Did you ohm check the circuit for shorts before you plugged it in ?
toque
Old Aug 11, 2012 | 06:39 PM
_Wayne_'s Avatar
_Wayne_
It weird I hook them up to a 9v they work and it works and everything in the car (except lights) but now I got all these ground errors so I don't know I may have let the magic smoke leave and just need a new unit or power supply?
To HVAC help!!
