Squealing in Engine
Old Aug 13, 2012 | 12:27 PM
lavery48's Avatar
lavery48
Default Squealing in Engine
1998 C5 168,000 miles. I have a squealing noise and it sounds like mid to rear of engine. Everything on front of engine has been replaced, even has the noise when all belts are off.I fear it's something bad and getting worse.
Old Aug 13, 2012 | 01:00 PM
jim993's Avatar
jim993
When does it make the noise? At idle? Does the engine idle relatively smoothly? If only shortly after startup, a leak in the secondary air injection system or maybe a partially stuck secondary air check valve could make noise, but only while the air pump is running.
Post codes, if any.
I wonder if a vacuum leak might have developed, making a sound that might sound like a squeal. Has the manifold been off recently?
If you don't have one, get an automotive stethescope at your auto parts store and see if you can pinpoint location.
Old Aug 13, 2012 | 02:21 PM
lavery48's Avatar
lavery48
Yes, the manifold has been off and the exhaust manifolds. I thought I was going to have to pull the engine to replace the Marmonic Balancer but as it turned out I didn;t have too. After I assembled the engine back togeather is when the squealing started.It seems to run smooth all the time and the noise comes and goes at different RPM's and speeds.
Old Aug 13, 2012 | 02:50 PM
NukeC5's Avatar
NukeC5
Like jim said, it is most likely a Vacuum leak then. Intakes will make a noise like that if they are not sealed correctly. Is it just the noise or is it running strange too? It should have hesitation if it is really bad..
Old Aug 13, 2012 | 03:20 PM
lavery48's Avatar
lavery48
It seems to be just a noise, as far as running it does just fine.
BUt it does seem to be getting louder.
Old Aug 14, 2012 | 04:20 AM
lavery48's Avatar
lavery48
Back in the day I have squrited WD 40 on a intake to see if I could hear a leak, can I do that to this motor and check for leakes ?
Old Aug 14, 2012 | 09:13 AM
lavery48's Avatar
lavery48
Hows the best way to find this leak if there is one ? WD-40 sprayed on the motor ?
Old Aug 14, 2012 | 10:40 AM
NukeC5's Avatar
NukeC5
I wouldn't know on any newer cars either... it should act the same. Its still a Vacuum issue whether carbureted or fuel injected.
Old Aug 14, 2012 | 12:30 PM
dadaroo's Avatar
dadaroo
Here is a good You Tube video on finding vacuum leaks. I would recommend using propane. You don't have to cut the torch, you and use a couple of different size hoses to mate up to the torch. I would still recommend having a fire extingusher handy, but it really is a very safe approach. If that does not identify a problem then is is quite possible you have an exhaust leak. That can be better found with an automotive stethescope to find your leak.
http://www.youtube.com/watch?v=9CPqbaSgcok
Old Aug 14, 2012 | 04:15 PM
jim993's Avatar
jim993
Good stuff on the ericthecarguy.com video. I could hear the vacuum leak squeal on the video.
To Squealing in Engine
